Sponsored by: Real Truck
Anyone Measure Diff Temps?
Old Sep 20, 2011 | 09:55 PM
XB70's Avatar
XB70
Do any of you guys have differential temp gauges?
I ask because I'm about to wire brush the rust off my stock 2005 F250 rear differential cover and want to apply a rust converter product. I have a spray can of Rust-Oleum Rust Reformer that I'd like to use as a primer, but the instructions state not to apply it to surfaces that eill exceed 200 F.
So, how hot do our differentials run?
The instructions also state ot to apply to galvanized metals. The diff covers can't be galvanized, right? Not when they rust like they do.
Old Sep 20, 2011 | 10:26 PM
SteveH-CO's Avatar
SteveH-CO
My diff runs about 135F on the highway, not towing. I doubt many would exceed 200F. The OEM cover is not galvanized. The alloy covers that Ford used starting in 2006 or so are fairly inexpensive ($70 or so) compared to the aftermarket ones.
I think you'd be fine with your Rustoleum product, or just use phosphoric acid, and then spray it with black paint, cold galv. compound, whatever you like.
Old Sep 20, 2011 | 11:30 PM
XB70's Avatar
XB70
Thank you. I thought it would be under 200F.
My plan is to coat the OEM cover for now. I'll replace it with the factory aluminum cover when I change the fluid.
I just finished removing the loose scale with a wire brush (used with power drill). I was surprised that the cover was in good shape. There was light surface rust, but 60% of the paint was still on the cover. The dirt made it look like the rust was pretty bad.
I guess what the Wyoming Department of Transportation told me was true: They don't salt the roads and use a chemical that is harmless to metal. (The City of Cody spreads sand at city intersections with about 2% salt to keep it from clumping). After five winters, there's not one speck of rust anywhere on my truck except the diff cover.
My friends who live on the beaches of Southern California had more rust issues from the salt in the ocean air.
Old Sep 21, 2011 | 04:14 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I've measured diff temps. When towing in 100°F and above, up a grade, I've seen 300°F temps. Running empty they probably don't go above 200°F.
Old Sep 21, 2011 | 04:39 AM
XB70's Avatar
XB70
Thanks, Mark. I just finished masking the diff. Found a can of Rust Oleum High Heat (1,200 F) paint in the garage.
Old Sep 21, 2011 | 06:27 AM
1975StroppeBaja's Avatar
1975StroppeBaja
That's about what mine runs normally as well.
I had a longish (~150mi) stretch of all interstate driving when we went to TN last summer and sustaining 70mph for that far, it crept up to the 160 range by the time I got there.
Old Sep 21, 2011 | 03:14 PM
mwsF250's Avatar
mwsF250
With Mag-Hytec cover on 100+ degree days, I have seen just above 250 on long hard pulls up the Sierras and Cascades.
Not towing, rarely over 150.
wrobo23
Paint & Bodywork
Jun 29, 2007 05:36 PM
murph1
1997 - 2003 F150
Oct 5, 2005 09:20 AM
Caniac10
Jan 8, 2005 05:42 AM
tomsf150
Paint & Bodywork
May 11, 2004 11:30 AM
Stingray42
Oct 24, 2003 06:27 PM
