Zero Rust experts
Old May 10, 2004 | 08:36 PM
tomsf150's Avatar
tomsf150
Zero Rust experts
Does Zero Rust dry to a gloss shine? What paints can you cover Zero Rust with? Would Zero Rust need to be sanded for top coating?
Old May 10, 2004 | 08:54 PM
Aekisu's Avatar
Aekisu
<cr>
Two coats produce a semi-gloss. If you want a gloss (and UV protection) topcoat it with Crystal Coat.
Well, that's a good question. ZR is designed to be a top coat. I have topcoated it with a urethane basecoat/clearcoat, after applying an epoxy sealer.
Like any paint, if you exceed the topcoat time, you need to scratch the surface. Flash times, topcoat times, and other info can be found here.
Old May 11, 2004 | 11:30 AM
tomsf150's Avatar
tomsf150
Zero Rust
Thanks for the advice
