302 to 351 swap wiring harness question
I'm at the point now that I have to figure what to do about the differences in the engine wiring harnesses. My truck is a '90 F250 that had a 5.0 in it. My donor engine (5.8) came out of a '92 F250. The main visual difference in the harnesses is that the 5.0 harness uses (4) small square plugs to connect to the main wiring harness on the drivers side fender well and the 5.8's harness uses (1) large square shaped plug to connect to the main harness.
How do I get this to work? From what I've read during my research on the swap the 5.0 harness used on the 5.8 will result in the injectors firing at the wrong time. I have a correct 5.8/manual ECU to use, I just need a bit of help to figure out the best way to get the correct harness for the engine.
Thanks for any help!
You're wasting your time here, there is no need to change any of the wiring for this engine swap, simply plug the 5.8 engine into the existing '90 engine wiring harness and attach a 5.8 computer, that's it. All the sensor and actuators are literaly the same and in the same places on both motors so none of that needs to change, and the computers are also wired the same so the '92 EEC will work with the '90 harness. Firing order doesn't matter with the batch fired EFI system either, injectors on both 5.0 and 5.8 motors are wired to the computer the same way.
Conanski,
the issue w/ the 5.8 harness is that it doesn't use the same type of main harness connection that the 5.0 uses,
so it sounds like I could use the 5.0 engine harness on the 5.8?
DING DING DING.. we have a winner!
Is your '95 mass air? If so you don't need to change anything(wiring or computer) simply put the 5.8 motor in where the 5.0 was and connect it to the existing 5.0 harness. And just to be clear that means remove the upper intakes from both motors and unplug ALL wiring attached to the engine right at the sensors and injectors, DO NOT leave ANY wiring attached to the donor motor and DO NOT remove ANY wiring from the truck.
What's wrong with the '87 harness?
Yes.. or a 5.8 computer from a trucks with a C6 auto.
Nothing but it is man trans 4.9,sorry forgot to say. Will that work with 5.8 and5.0 harness? Already have those and thought rather than modify harness just use them and use 5.8 computer.Will the 4.9 computer work with 5.0 harness and run 5.8? thanks for the help.
An '87 truck will have a unique harness on it regardless of motor so you're going to have some work to do anyway, if you have a complete V8 harness(engine all the way back to the EEC) from any year after 1988 then that will be the better one to use with a 5.8 computer.. which you will also need. And again to be clear you cannot mix portions of two different harnesses, it has to be a complete unmolested package from the motor all the way back to the computer.
