1978 - 1996 Big Bronco
88 302, starting issues
Old Sep 20, 2011 | 08:59 PM
fanslowj's Avatar
fanslowj
Exclamation 88 302, starting issues
I have an 88 302 with EFI, and have had this issue for the last 3 months. She will start every couple of days, full cranking power and starts right up. After the initial start, it does not start again. ( at least for 2 days)
the symptoms i get when it does not start is either a bad battery, ( slow cranking wa....wa....wa). then I can wait an hour go back out and it will act like a bad fuel pump, where i get full cranking power but it will not fire.
I am thinking it is electrical with the fuel pump, is there a way to bench test or test the fuel pump?
I have already had starter, battery, altenator bench tested, all are good, solenoid has been replaced, as well as repaired the fuseable link.
Ideas please it is not my daily driver but miss driving her very much, great machine when she is working right! Thank you for your time.
Old Sep 20, 2011 | 09:04 PM
AzPete's Avatar
AzPete
When you turn the key to on, listen for the fuel pump to be running. It runs for just a couple of seconds. If you cycle the key from off to run a few times before starting, that will help pressurize the fuel system. If this helps it start, you could have a fuel pump/filter/pressure regulator problem.
Old Sep 20, 2011 | 09:24 PM
fanslowj's Avatar
fanslowj
thanks for the reply, when it goes to that symptom, I can not hear the buzz of the fuel pump, but do have full cranking power.
when I hear the buzz of the fuel pump, I do not have cranking power, again it is like the battery is dead.
Old Sep 20, 2011 | 09:44 PM
AzPete's Avatar
AzPete
You need to verify battery voltage under both conditions to see if it is in fact low.
Possible ignition switch issue?
Check and clean the ground wires near the battery. They are bolted to the truck body. Remove and clean them.
Old Sep 20, 2011 | 09:54 PM
fanslowj's Avatar
fanslowj
i will have to verify battery voltage during each symptom, but have replaced the ignition switch, and terminals have been cleaned as well as the ground, it is grounded to the Frame of the truck not body, but frame i wire brushed to clean metal then attached. both positive and negative battery cables have been replaced as well.
Old Sep 20, 2011 | 10:24 PM
AzPete's Avatar
AzPete
Might try to pull the fuel pump fuse and see if the cranking speeds is always the same.
Also, does that truck have two fuel pumps? One in tank and one frame mounted? If so, could have one bad and one good.
Old Sep 20, 2011 | 11:06 PM
fanslowj's Avatar
fanslowj
Yes it has both in tank and frame mounted fuel pumps, but that is good advice I will try pulling the fuel pump fuse and see if that get my crank speed back to normal when experiencing that issue! That never crossed my mind! Thanks
DPDISXR4Ti
1983 - 2012 Ranger & B-Series
15
Jul 17, 2019 11:56 AM
Candie711
Modular V8 (4.6L, 5.4L)
Dec 27, 2016 07:16 PM
mmohio1991
1997 - 2003 F150
Nov 7, 2012 07:48 PM
Dave88F250
Nov 1, 2005 07:34 PM
kdbbmanton
Aug 11, 2005 09:19 PM
