Sponsored by: Auxito
Starting issue
Old Nov 7, 2012 | 07:38 PM
mmohio1991's Avatar
mmohio1991
Starting issue
The past week or 2 i have had an intermittent starting problem. Engine is turning over but wont start, but after i wait a second it will start up. I listened to see if the fuel pump was running and heard the whine. I checked the battery and the starter voltage and it was all good. i primed the fuel pump a couple of times and it started up on the first crank of the ignition. The truck runs great when driving and idling, no misses or loss of power that i have felt or heard yet. im thinking it is either the fuel pump is starting to go or mybe the fuel filter is getting a little clogged up. Like i said up above this is an intermittent problem and that is why im confused. Its a 2001 F150 4.6 4X4
Old Nov 7, 2012 | 07:48 PM
Bluegrass 7's Avatar
Bluegrass 7
Check fuel pressure at the injector rail to see what is going on.
After it sets awhile, put gage on and turn key on.
Pump should run about 2 seconds and begin to build some pressure.
If you do the prime several times the presure should come up to spec at about 35 psi +/-.
If not you have an issue.
No confusion about that.
Good luck.
sparks717
Nov 25, 2023 09:59 AM
Penton97F150
1997 - 2003 F150
Jun 26, 2016 10:49 PM
Wisconsinford
Jul 14, 2014 02:27 PM
gilmoresoonerfan
2004 - 2008 F150
Apr 29, 2011 10:06 AM
jasonhuber
1997 - 2003 F150
Oct 1, 2009 09:44 PM
