Ford 302 stalling issue?
Old Sep 20, 2011 | 04:13 PM
Equality 72521's Avatar
Equality 72521
Hey guys, I'm having an issue that's getting worse. Hoping I could get some advice. I have a 1983 F100, 135k with automatic and 302 V8. It has always stalled/died when I give it just a little gas at a stop light (or anytime I'm driving). I have to pull off the line with a little oomp. While moving, it I just give it a little gas it will jerk and make a loud clunk clunk clunk from what sounds like the drive shaft area. I have always had to warm the engine up before going anywhere to prevent stalling. If anybody can shed some light on this I would really appreciate it. Thanks.
Old Sep 20, 2011 | 05:20 PM
Franklin2's Avatar
Franklin2
With the truck off, take the aircleaner off, and with a flashlight look down the throat of the carb while you push back on the throttle. You should see two strong streams of gas pour into the engine. If not, then your accelerator pump is shot and the carb needs a rebuild.
Old Sep 23, 2011 | 06:43 PM
Equality 72521
Thanks Franklin2, I will give that a shot.
dan1802
Aug 14, 2011 08:35 AM
mightyfine79
May 11, 2006 10:09 AM
bassman57
Aug 29, 2003 03:23 PM
airwulf
1978 - 1996 Big Bronco
Jun 10, 2001 09:51 PM
Brandon_J
Mar 19, 2000 08:15 PM
