no dash lights
Old Sep 20, 2011 | 11:01 AM
matt14's Avatar
matt14
no dash lights
Ok I have an other light problem with my 94 f250 diesel stick, no dash lights every thing else works just no lights working of the dimmer switch. Any help please
Old Sep 20, 2011 | 11:27 AM
jplinville's Avatar
jplinville
My bet is the rheostat dimmer switch. Pull it out and clean it with contact cleaner, or replace it with a new one.
Old Sep 20, 2011 | 11:31 AM
streetlude95's Avatar
streetlude95
same thing happened to mine but i just instaled LED's
Old Sep 20, 2011 | 12:20 PM
matt14's Avatar
matt14
My bad I did not give all the info i've replaced the switch, because when the lights where turned on it would blow the fuses for the interior light and running lights. Now they work as they should including turning on the dome light but nothing works off the dimmer.
Old Sep 20, 2011 | 03:33 PM
White 97 xlt's Avatar
White 97 xlt
There is a separate fuse for the instrument lights, it gets it's power from the running (tail light) light fuse..
So if the running lights are working check the instrument light fuse, if not check both..
Old Sep 21, 2011 | 09:54 AM
matt14's Avatar
matt14
tested fues are good but no power to the instament 5amp fuse when I put power to that fuse it blows like dead short, with dash completly out and unpluged along with radio and heater contrler
sand1
15
Oct 27, 2016 01:22 PM
islanddave
16
Jul 23, 2007 11:34 PM
FordPickup460
Nov 21, 2004 12:51 PM
walkpast
Jul 20, 2004 05:21 PM
ddavidv
Dec 1, 2003 09:07 PM
