You didn't happen to have a FICM performance code did you? I know you had a poor connection code, but I know when mine was starting to go my dashDAQ was giving me a FICM performance code on one of the harder to start cold mornings in Plano.
It may not be there, I just know that's the only code that I got when mine was going on. However, based on what I'm reading I would still say FICM and/or electrical.
Hopefully you are not surprised too badly by the bill (or better yet - it is under warranty). Sending the FICM off for repair (and component upgrade) can be done for $200-$250 when you DIY.
Do you guys usually do your own FICM or let the dealer do it? I have been looking at the refurbished ones on EBAY, with like a year warranty. Not sure how I feel about that...
It is not under warranty. From what I read on here, the FICM is about $1300? I read and watched a Youtube video on DIY as far as the FICM. I am not the most handy person, so I am not sure how well I could do that fix!
Alright, here is the damage, about $1500. They said the FICM needs to be replaced and removed (no surprise there), but what got me is that they said I needed two new batteries because mine were "toast"....now I do know they were losing power because I was trying to get it started...but does it mean they cant be recharged?? I have never heard of that! He says the cranking amps have dropped to low, and once that happens, that it for the batteries, lol...any thoughts?
It depends how old the batteries are. I had the same symptoms last winter and killed my batteries twice before taking the plunge on a FICM. Luckily my batt's were only 2 years old and able to be re-charged.
The repair is very simple, move the overflow bottle to the side, remove the air filter box, and it's right there. but the new FICM will have to be reprogrammed by the dealer (heard of this never being done, never seen it myself)
^Piolet, my family used to have a summer home by scobie pond, I miss that place.
FICMrepair.com - $220 to $250.
Removal of the FICM is easy.
The FICM is almost 100% certain to be repairable.
Have it towed home and pull it yourself and have it repaired - you will still be money ahead.
You could also post up on the Forum for your state (state chapter) and see if anyone is available to help you.
I let the dealer know I would be towing the truck home (they were not the happiest campers, even told me they had "never heard of repairing an FICM, lol). According to the site, the unit does not need to be programmed...I guess since they are repairing the one that was already in there, it is already programmed?
