fuel gauge help
Old Sep 19, 2011 | 03:26 PM
jasonford1986's Avatar
jasonford1986
fuel gauge help
I've got an 86 f250 with dual tanks previous owner cut fuel lines now only front tank works. My question is I've got no fuel gauge now I've chased it back to the yellow and white wire from cluster and a blue wire from tank. I jumped them and it works but it never says the samething. With a test light I checked yellow and white wire but its not a steady current it flashes. Does anyone know a way to make it work like this
Old Sep 22, 2011 | 09:19 PM
eriklane's Avatar
eriklane
Fuel gauge wiring
I have an '86 f250 with only the front tank also, and no tank motor. I believe the blue/white and yellow/white wires need to be connected-and I have the same issue-mine always reads E, but not below. The flashing is right-and it should vary in ohms from 10-90 or something...if you can get the sending unit out carefully (it can be done under the tank if you use a chunk of wood or brass drift to punch off the holding ring and then carefully lift it out...) The rheostat inside has a little tang that rubs on a circuit board and thus registers the varying ohms...Mine reads right but still doesn't make the gauge work right...Hope this helps some....is your tank switch motor out also?
JBMorrey
27
Dec 4, 2017 12:11 PM
blk450er
Oct 13, 2016 09:14 AM
FORDF250HDXLT
May 11, 2016 07:54 AM
carter442
Nov 6, 2008 08:52 PM
Gene Marsh
Jul 29, 2003 09:35 PM
