Fuel Tank reading question
Back story, the gentleman I purchased the truck from was no mechanic at all, and would always just take it to repair shops, well about a year ago, he had the fuel tank replaced, looking at it in my truck, it's a shiny silver tank. So when he told me the gauge was not working, I thought surely it was not the sending unit as I would assume that was replaced when they put in a new fuel tank, but you never know. I assumed it was a bad actual gauge or ground.
So my question is....... How can you test if a tank is full without being confident in the reading you are getting? I thought possibly of "knocking" on the fuel tank to see if it sounds full.... but not sure.
Seems like the gauge is functioning at the dash, because it does move, but seems strange that it moves past the full mark, then again, I remember my first car in 1987 (57 Chevy) did the same thing when I filled the tank.
Any thoughts are suggestions are appreciated.
James
1) The tank actually is very full. The gauge needle will normally go past full when it is completely full. (Your only being able to fill in a gallon or so supports this.)
2) The tank is less than full but the sending unit or gauge are reading off.
3) There is a short in the wiring to the gauge and the sending unit wire is grounding. When the sending wire is grounded, the gauge will peg over 'full'.
Easiest way to test is to unplug the green sender wire (on mine there is a plug on the driver's side front of the tank.) If when you do that your gauge drops to empty, most likely you just have a full tank.
One thing to check is how thick your tank is... if the PO replaced the standard tank with one of the big 38 gallon tanks (you can tell the difference by the thickness of the tanks, the 38 gallon tank is about a foot deep) you may have all kinds of fun trying to get a decent reading from your gauge.
Thanks, so I am going to look this evening, I need to get under the truck and on the drivers side front of the tank, I will see a wire to unplug, any chance of there being some kind of photo of what this should look like? Or is it obvious, like only 1 wire under there to unplug?
James
James
Heres what the connector looks like<br/>
James
James
James
If I was a gamblin' man, I'd just throw a can of gas in the back and drive it. If it goes 200 miles you know it was full!
If it sputters and dies in 20 miles, you can then fiddle with it's bits then.
The reason I use the gambling metaphor is that in the old days this was not a big deal, even for someone with just one tank. You just pull to the side of the road, pour gas in and away you go. Nowadays with roads so crowded (depending on where you live) and fuel so crappy, and fuel pumps so prone to failure if you look at them sideways, and trouble re-priming a weak or worn out pump, this little roadside fill-up segué could turn into a full blown overnight adventure!
Hah! So I'm maybe taking a little poetic license here. But since we really don't know the condition of the truck because you just bought it, you never know what's going to be next on the list.
Congrats on the new-to-you truck too though, by the way!
And if you have both tanks on yours, then all of the above is just talk. Once it sputters you flip the switch and keep driving on the other tank.
Assuming you put gas in it of course!
Good luck.
Paul
I think I will try that first, I have a little 2 gallon gas can I can put in the bed while I drive around, surely it will move eventually.
Right now I am going through plenty of things popping up on this truck trying to get it Road worthy. First the carburetor, Then all 4 shocks.... thought I was ready and realized my right turn signal was not working, fixed that and my backup lights do not turn off (Still need to address that situation) and last night when I drove to the gas station, I noticed some slight looseness in the steering and a shake. I have yet to take it over 40mph so who knows what to expect then. I have a feeling a tire balance and rotation is in my future, at the minimum. The truck sat in a driveway for about 6 months so hopefully the tires did not rot at all.
James
"Disconnect the wire that goes to the fuel sending unit at the tank. Ground that wire to the frame, making sure the frame is clean. Turn the ignition to the "run" position and watch the fuel gauge. If the gauge swings all the way to full, either the sending unit itself is bad or it has a bad ground. If the gauge stays on empty then either the gauge is bad or there is a wiring problem.
To pop the plug off for the test, you can barely get up in there with your head and see the plug. While looking at it, VERY CAREFULLY use a screwdriver to pry it off. AND I MEAN VERY CAREFULLY. It is only pushed on like a 1/8". This is only if you can’t get it with your hands.
Once you have done the test (above) and decide it’s the sending unit. And you have cleaned the ground and that did not work. Then disconnect the ground again and fuel line and read on….
If you can't get either one disconnected, no worries you will have a little more room once the tank is dropped down a little. But make sure you have some wire slack in the plug connector.
Run the tank dry or almost or siphon it empty, I would not do it with ½ a tank of fuel, but if you just have to, just use a big floor jack and a piece of 2x2 plywood. It’s not heavy at all, unless you have it full or 1/2 full of gas. JUST SIPHON DRAIN THE TANK!
Loosen the filler and vent hose clamps at the tank end and maybe you can pop the lines off? But most of the time you have to just loosen the clamps and wait till the tank is about out.
With the jack in place, or not, just loosen the hdwr (2 bolts) on the front straps, and remove the tank straps aft hdwr all together, then swing the straps out of your way.
Slide the tank to the dvrs side about 1/2" and then pull out or let the passenger side come out of the frame. Then disconnect the elec connector and eng feed fuel line if you could not get to them earlier.
Then slide it as far as you can to the right and pop off the filler/vent lines. Sometime you need to carefully put a flat tip screwdriver in between the rubber hose and the tank to break it loose. The filler neck and vent lines get stuck to the metal pretty good sometimes. Once the tank is removed there is a lock ring that comes off with a screwdriver or punch, look for a small tab that has been bent over to lock it. Un-bend it, tap off the lock ring, remove the sending unit.
Insp the underside of the tank where the support straps rest, lots of dirt and moisture build up there, and that causes the bottom side corners to rust out. You can also come reinstall time replace the anti-chaff material. Old 2" ratchet strap work great, glued to the support straps.
Insp the inside of the tank, might be a great time to replace it all together? Before you reinstall anything connect the electric connection and ground to the sending unit. Wire it up under the truck so it is not hanging by the connection. And with the key in the 1st (on position) you should be able to move the float arm and see a difference in your gauge?? It is always easier to do this with a helper.....
Also before install, paint the complete tank with some good paint. Even spray on bed liner or undercoating??"
James
