cab swap differences
Old Sep 19, 2011 | 10:58 AM
mrblonde108's Avatar
mrblonde108
the 92 up cab firewall is different. Will the older steering column and all bolt into it? the older ones look like it has a plate spot welded on and the wire harness holes are different as well as e-brake.
TIA
Old Sep 19, 2011 | 11:09 AM
Onus's Avatar
Onus
92 up cab also has rear speaker mounts for regular cabs. You can cut the pedal section out of the 92+ cab and replace it with the 91- cab.
Old Sep 19, 2011 | 11:33 AM
mrblonde108
Ok good. that gives me more options. I guess the older cabs have a stronger firewall area because my 1998 f800 cab has the plate like the older cabs have. It has a cable pulled clutch with a fuller eaton manual transmission.
Old Sep 19, 2011 | 04:11 PM
cj06's Avatar
cj06
are you talking about cabs on medium sized trucks or F350 and smaller ?
Old Sep 19, 2011 | 05:32 PM
mrblonde108
Both i want to put a ext cab or crew cab on a 1998 f800. but i just realized the cabs look the same but are different or modified. as well as having that plate like the 92 down it has a whole different dog house. I have to investigate more.
Old Sep 19, 2011 | 05:48 PM
cj06's Avatar
cj06
the steering columns go threw the cabs in different spots on the 2 , i was going to do the same with my old 86 f250 extenda cab on my older 1970 f600 ! it will be a project for when times get better or more money to play with !
Old Sep 19, 2011 | 06:33 PM
Onus's Avatar
Onus
If you use the older style consider this: Terrapin Manufacturing
Old Sep 19, 2011 | 07:53 PM
mrblonde108
i would not think the olde rones had problems .I would think they would be stronger with the double plate.
flatratetech
Feb 3, 2018 07:49 PM
Built_Ford_Tough_757
Aug 9, 2015 12:25 PM
264WSM
Jul 5, 2015 09:31 AM
Pitcher
Sep 27, 2012 02:08 PM
2ktrott
Jun 10, 2010 01:58 PM
