Cab Swap question
Old Sep 26, 2012 | 11:51 AM
Pitcher's Avatar
Pitcher
Cab Swap question
WIll a 1995 F150 cab fit on a 1988 Cab and chassis F350? i.e. will the mounting locations be the same?
Old Sep 26, 2012 | 01:12 PM
Evan_P's Avatar
Evan_P
As long as they are the same type of cab, everything should line up on the frame. The cab on the truck's have been the same since basically 1980 if I'm not mistake. They just changed what everything around and in the cab looked like. The only thing I would double check is mounting the 1988 interior in a 1995 cab. Not sure if that can be done without modification.
Old Sep 26, 2012 | 01:19 PM
Pitcher's Avatar
Pitcher
Thanks Evan.
My plan is to take the entire cab, fenders, and interior as a whole and swap it.
I know this was possible on the late 70's trucks, and I am curious if it is the same on these.
Old Sep 26, 2012 | 01:59 PM
Diesel_Brad's Avatar
Diesel_Brad
Yes, mounting points are the same 80-97
But the wiring harness and how it enters the cab is Completely different
Old Sep 26, 2012 | 02:12 PM
Evan_P's Avatar
Evan_P
That's what I thought, just wasn't sure.
Old Sep 26, 2012 | 07:00 PM
2002 F350V10's Avatar
2002 F350V10
Im under the impression the front frame is slightly different for mounting the core support/front bumper . It requires tweaking.
Old Sep 26, 2012 | 08:04 PM
Diesel_Brad
No. you can put a 1980 cab and nose on a 96 and vise verse with no "tweaking"
Old Sep 26, 2012 | 08:42 PM
fordka's Avatar
fordka
i had a guy look at the 95 cab i had that wanted to put it on a 89 cause hes already 3 cab swaps on that truck before he said the panel for the parking brake mechanism has to moved further down or something like that for the older year trucks. didnt know what but thats what he said and he seemed to know a lot about it.
Old Sep 27, 2012 | 06:50 AM
Diesel_Brad
There are quite a few difference between the interior of the 80-86/87-91/92-97
Old Sep 27, 2012 | 08:49 AM
sticky58's Avatar
sticky58
I have done such a swap, I have a 95 on a 82 frame,the only differance is in the way the bumper mounts to the front.You`ll need to ad the bracket mounted to the frame to accept the bumper, I think I used the bracket off a 87-91..
Old Sep 27, 2012 | 09:17 AM
Pitcher's Avatar
Pitcher
So it sounds as if I move the cab and clip as a whole it will bolt up, but if I want plug and play with wiring I need to find one with a 460 EFI in it?
Old Sep 27, 2012 | 02:08 PM
Diesel_Brad
Correct, or at least a EFI harness
flatratetech
Feb 3, 2018 07:49 PM
turbill
13
Dec 16, 2011 07:38 PM
2ktrott
Jun 10, 2010 01:58 PM
460powerhouse
May 29, 2010 02:21 PM
907ford
13
Jan 7, 2010 04:52 PM
