Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
IAC experts question
Old Sep 17, 2011 | 11:17 AM
bpounds's Avatar
bpounds
How does this IAC look? This is off the truck on the bench. In the first pic you can see the valve is cracked open a bit. This is how it was when I pulled it off the truck. In the second pic I have pulled it back a little with my fingernail, and as you can see the spring does not close it. I guess I expect a spring loaded valve to be closed normally.
This valve has about 35k miles on it since it was changed. The truck has 117k on it. It is running okay, and starts okay, but does not snap to life like it has in the past.
Old Sep 17, 2011 | 11:28 AM
barthel's Avatar
barthel
Bill,
Mine looked and acted exactly like yours when I pulled it off. After I cleaned it and put it back on it worked fine. I guess as long as the spring is working you're good.
Old Sep 17, 2011 | 04:53 PM
SpringerPop's Avatar
SpringerPop
What's with the spring loading?
IACs are usually driven open and closed by a jackscrew driven by a stepper motor.
Dunno'....
Pop
Old Sep 17, 2011 | 07:10 PM
bpounds's Avatar
bpounds
Thanks for the comments. I cleaned it up, even though it was very clean for 35k miles, and put it back in. It seems fine, but the stumbling start was so occasional that I doubt we will notice anything changing.
Pop, the bonnet floats on the shaft, and feels like it is opposed by a spring. And on the closed end there is a spring that is probably just an end of stroke cushion. So I was guessing it is a linear servo. Only a guess.
I cleaned up the throttle body with some carb cleaner, fixed my cruise control cable, and all seems well.
Need a new battery sometime before winter.
Old Sep 17, 2011 | 09:25 PM
SpringerPop
Four wires to the valve?
If so, likely that's a stepper.
Pop
Old Sep 18, 2011 | 10:42 AM
bpounds's Avatar
bpounds
Only 2 wires, Pop. Which means it is simply a solenoid valve. Which also means there is no feedback, which is why a failed/dirty IAC rarely sets a fault.
Old Sep 18, 2011 | 10:01 PM
SpringerPop
Well, the "feedback" is sensing the RPM, but you've got the operation nailed, Bill. Two wires equals simple solenoid or DC motor with polarity reversal.
Pop
Old Sep 20, 2011 | 10:33 AM
martin_csr's Avatar
martin_csr
Originally Posted by bpounds
This valve has about 35k miles on it since it was changed. The truck has 117k on it. ...
Is that a genuine Ford part or aftermarket?
Old Sep 20, 2011 | 10:40 AM
bpounds's Avatar
bpounds
Ford. Installed by a dealer.
swmddo
May 6, 2019 04:40 PM
ncheavymetal
North Carolina Chapter
157
Jun 12, 2012 03:16 PM
04F150N56F100
Feb 22, 2010 08:20 AM
pdqford
Apr 5, 2009 12:57 PM
Storm
May 2, 2007 12:12 PM
