Mystery Spring
Old Feb 21, 2010 | 07:15 PM
04F150N56F100's Avatar
04F150N56F100
Mystery Spring
Anyone recognize this spring? It ended up in a group of parts that were painted and now I don't have a clue....
Parts it was with were a clip from inside generator to hold the bearing in the end cap and a throttle return spring.
Last edited by 04F150N56F100; Feb 21, 2010 at 07:16 PM. Reason: try to show picture
Old Feb 21, 2010 | 07:17 PM
04F150N56F100
[IMG][/IMG]Ok, not sure what I did wrong, seemed to work the second attempt.
Old Feb 21, 2010 | 07:30 PM
fixnair's Avatar
fixnair
That sure looks like a brake spring to me. Is it round or oval?
Old Feb 21, 2010 | 07:32 PM
treetrunks's Avatar
treetrunks
that looks like a brake shoe hold down spring to me.
Old Feb 21, 2010 | 07:45 PM
04F150N56F100
Thanks guys!
I had not thought of that...but it can't be. Brakes were removed in front as a unit, doing a disc upgrade. Back are still intact. Did remove clutch / brake pedal, intake / carb / waterpump /generator.
Spring is round 1/2" diameter and 3/4" long.
I thought it might have been off the clutch arm as that was part of the truck being disassembled. I think that spring is much larger.
It wouldn't be from inside the generator would it?
I rebuilt the generator, new bearings...would...just can't find a pic of any springs inside.
Got sidetracked and truck has sat for a long time. Time to get it back together.
Old Feb 22, 2010 | 08:20 AM
dmptrkr's Avatar
dmptrkr
There is a spring about that size in the canister oil filter assembly.
