Need Injectors??
Old Sep 16, 2011 | 04:48 PM
greenmachine07's Avatar
greenmachine07
Need Injectors??
ok so while trying to figure out why my truck sounds like it misses when around 1200 rpms I pulled the valve cover thinking it could be my uvch. to my suprise it already has the ford tabs under the connector and was seated snugly. So I rechecked my ohms on the outside of the harness and i'm getting 4.3, 11.5, 5.5, and 7.6 ohms on the injectors. does that indicate bad injectors? I dont have access to any software to do buzz tests and dont exactly have the cash to have a shop tell me something i can check with a multimeter.
Thanks for the help in advance
Old Sep 16, 2011 | 04:54 PM
snakedoc's Avatar
snakedoc
check the injectors right on them. it can be a bad harness.
Old Sep 16, 2011 | 07:10 PM
greenmachine07
alrighty i'll try that hopefully tomorrow.
Old Sep 16, 2011 | 09:20 PM
BigAlsPSD's Avatar
BigAlsPSD
While you have the valve covers off, start it and check the discharge of oil coming out of each injector too, it will help point you to possible worn injectors.
Old Sep 16, 2011 | 09:21 PM
greenmachine07
I had the cover off today to check the harness because I thought it was the issue.. I ran it with it off and the oil coming out seemed pretty uniform between those 4 injectors.
Old Sep 16, 2011 | 09:51 PM
BigAlsPSD's Avatar
BigAlsPSD
Well that's good, should be about a teaspoon or so evenly out of the discharges.
Old Sep 17, 2011 | 11:21 AM
greenmachine07
thats about what it looked like. with it reading that amount of resistance, what would that cause on the truck?
Old Sep 17, 2011 | 12:27 PM
BigAlsPSD's Avatar
BigAlsPSD
When you are measuring resistance you are checking the solenoids for the injectors, variances in resistance can be due to a lot of factors, possible winding partially grounding out, wire's touching various things in the harness, corrosion or carbon built up on pins.
Old Sep 17, 2011 | 12:35 PM
greenmachine07
when i measured the ohms I did it from the outside of the valve cover harness.
Old Sep 17, 2011 | 12:37 PM
BigAlsPSD's Avatar
BigAlsPSD
Then like Matt said, check the harness injectors where they connect to help isolate where the issue is.
greenmachine07
alrighty, hopefully I'll be able to get to that this weekend
simms63ss
Apr 26, 2011 06:32 PM
texas5.0
28
Feb 2, 2011 07:42 AM
Brown Falcon
29
Jun 23, 2010 11:30 AM
97haymachine
Apr 17, 2010 11:39 PM
walkerplay
Sep 9, 2008 02:59 PM
