new injectors
Old Sep 5, 2008 | 01:53 PM
walkerplay's Avatar
walkerplay
new injectors
is it possible for another injector to go back on the same side. after replacing 3 and 7
Old Sep 5, 2008 | 02:11 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Not quite understanding what you are saying.
Old Sep 5, 2008 | 02:28 PM
walkerplay's Avatar
walkerplay
After Replacing 3 And 7 Injectors. It Ran Fine For About A Day.now Its Running Very Badly .
Old Sep 5, 2008 | 03:27 PM
miller_feed
If you did the labor, you may have a loose connection under the valve cover. Sounds like a connection is not tight.
Old Sep 5, 2008 | 07:05 PM
F350-6's Avatar
F350-6
Did you get new or rebuilt injectors? Yes anything is possible. The new injectors, or the ones next to them could have gone bad. You can try pulling the passenger valve cover (since you're worried about that side) and with the engine at idle watch for the oil spout to spit out oil from each of the injectors. The oil coming out of each injector should look the same.
While you're in there, re-check the torque on the injector hold down bolts. Another member recently changed injectors, then had an issue with a loose injector that left him stranded overnight. If an injector is really loose, you may need to pull it and inspect the o-rings to make sure there is no damage on them.
Old Sep 5, 2008 | 07:44 PM
walkerplay's Avatar
walkerplay
they are reman. i will try looking at the injectors tommorrow.. thanks for the help
Old Sep 5, 2008 | 07:47 PM
bdrummonds's Avatar
bdrummonds
how many miles since the change? After an injector change you can need up to 150 miles of driving before all the air is worked out of the HPO system.
Old Sep 9, 2008 | 11:47 AM
walkerplay's Avatar
walkerplay
ITS been abot 200 miles on it. starting to run worst now.
Old Sep 9, 2008 | 01:25 PM
orng1's Avatar
orng1
I'd look at the harness and go from there. Like the others have said, it's possibly a bad connection.
Old Sep 9, 2008 | 01:59 PM
John311t's Avatar
John311t
I have learned to stray away from Reman injectors, I have heard stories about how some of them come out of the shops. Good thing I have 24 injectors now to play with lol, so I shouldnt need to buy injectors for awhile.
Old Sep 9, 2008 | 02:59 PM
Kwikkordead's Avatar
Kwikkordead
Same here. I learned the expensive way on that one myself.
Put a set of rebuilts in and the truck ran worst than the ones that I took out.
Had to go buy a whole new set of Alliants to get my motor back.
