oil pan
Old Sep 16, 2011 | 02:00 PM
amthatiam's Avatar
amthatiam
oil pan
94 ranger 3.0 4x4 has leaky oil pan gaskets, shop says that the engine needs to be pulled to replace them, is this true? Thanks.
Dan
Old Sep 17, 2011 | 07:47 AM
tomw's Avatar
tomw
I think so. You have to pull the 2.3 to remove the pan, so why not the 3.0...? You could check that the PCV valve is working properly, and pulling a slight vacuum on the rocker arm cover where the tube leading from the air cleaner is connected. If the PCV won't pull a vacuum, slight, at idle, after a few minutes, then the PCV isn't working or you have blowby.
The other thing you can do is to tighten all the pan bolts to the specified torqe. You will have to drop the starter, I think.
The gasket is made of a, likely synthetic, rubber that will stay flexible seemingly forever. If it is installed with the bottom of the block or the pan gasket surface oily, it can ooze out of place and allow leakage. You may luck out with a little effort.
tom
Old Sep 18, 2011 | 02:52 PM
Phinxter's Avatar
Phinxter
My pan is rusted and leaking a bit and I'm in no hurry to replace it. I was looking at alldata and you don't actually have to remove the engine (so it says) but lift it as far as possible, still the labor time is over 9 hrs. So how bad a leak is it?
Old Sep 18, 2011 | 03:16 PM
maytag906's Avatar
maytag906
Lots of those vintage Fords have leaky pans, they rust out. I've replaced 3 of them over the years, on a 86 E350 diesel, a 92 F 150, and a 97 F 350.
5speedahead
29
Mar 11, 2017 07:38 PM
ultraranger
Nov 1, 2014 10:05 AM
mytruckisolderthanme
Mar 23, 2013 08:46 AM
totin_tools
15
Nov 17, 2009 11:24 AM
drew1701
Nov 5, 2006 08:50 AM
