Lighter socket not working
Old Sep 16, 2011 | 12:07 PM
mini1's Avatar
mini1
The upper 12v power port is working fine, but the lower lighter socket is not working. I'm assuming its a fuse issue. Where is the fuse and what number is it? Can put a heavier duty fuse in so this won't happen (I assume the last owner plugged in something that blew it)?
Also, is there a way to make them switched with the ignition? The power port is always on, which is no good for my auto on/off satellite radio and GPS.
98 E250 5.4 cargo
Old Sep 16, 2011 | 02:11 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
No help, but never put in a heavier fuse than it calls for. It's made to protect your wiring.
Old Sep 17, 2011 | 09:48 PM
mini1's Avatar
mini1
Anyone know?
Old Sep 18, 2011 | 07:39 AM
JWA's Avatar
JWA
Might help onlookers if you simply identify the year and model of you van!!
Old Sep 18, 2011 | 07:53 AM
Club Wagon's Avatar
Club Wagon
Better double check 1st.
Originally Posted by mini1
98 E250 5.4 cargo
Old Sep 18, 2011 | 08:20 AM
JWA's Avatar
JWA
How about contributing something to the thread instead of interjecting something not helpful!
Old Sep 19, 2011 | 12:36 AM
86scotty's Avatar
86scotty
If this van is fairly new to you, or if you have any other electric options not working, i'd recommend getting under the dash with a flashlight and pulling all of them and visually checking them. Also, there is a 2nd fuse box under the hood which is easier to get to. I'd pull those too. Use a pair of needle nose pliers. This is time consuming but i do it usually when i get a new vehicle. You never know what you might find blown!
Also, i don't know what exact fuse you should pull but it's listed in your owner's manual if you have one. Sorry, mine is not close.
Old Sep 19, 2011 | 05:11 AM
JWA's Avatar
JWA
Hey Mini1 another idea--it's helpful to have an EVTM (Electrical/Vacuum Troubleshooting Manual) for your particular year and model of van, especially if you do any sort of trouble shooting on your own. These are in book form and contain a lot of schematics along with fuse box layouts and vacuum routing as well.
I find mine on eBay, typically less than $20 each in nearly new or VGC---they're plentiful over there.
HTH
Old Sep 21, 2011 | 05:12 PM
mini1's Avatar
mini1
Replaced fuse 23 for lighter socket and its back online! I opened up the panel and was removing the fuses to swap 23 and 28 to see if the fuse was the issue and I didn't even notice that Ford actually installed a full set of back-up fuses on the rear of the panel door! All were there and new. Wow, thanks Ford!
Where would I find a set of these fuses besides the dealer? I need to replace the one I just took.
Also, does anyone have any ideas on who to make the power port switched with the ignition?
Old Sep 21, 2011 | 06:09 PM
86scotty's Avatar
86scotty
Any auto parts store, Walmart, even convenience stores have these fuses sometimes.
To make a power port switched (with ignition), find your switched power wire for your radio right beside the power port and splice in to that. You can find a radio wiring diagram at installdoctor.com
Old Sep 21, 2011 | 08:09 PM
Club Wagon's Avatar
Club Wagon
"...!!" "...!!" "blah...!!"
My contribution was clearly "helpful" enough to "help onlookers" like you "simply identify the year and model".
John Hubbard
Sep 25, 2015 09:28 AM
work.truck
Mar 16, 2015 08:07 AM
TheRifleman
Electrical Systems/Wiring
Jan 20, 2014 01:34 AM
steelhead2
Jun 13, 2011 10:40 PM
kms910
May 27, 2004 02:56 AM
