Clutch Linkage
I am trying to make my clutch linkage like new so it will work right.
But to remove the bracket you show you just need to remove the cotter pin, nut and washer and it should wiggle off as its most likely a keyed hole to keep it from moving around. This particular part is a 65/66 F100/250 2WD only part...C5TZ7A554A.
- cs65
I looked for the C5TZ-7A554-A, and no one seems to have one, so I will take it off and take it to some Fab guys I know and get them to reman one for me.
C0AZ-7526-B (replaced C0AZ-7526-A) .. Clutch Relay Rod Nylon Bushing / Obsolete
Applications: 1961/72 F100/750 / 1966/77 Bronco / 1973/77 F100/350 / 1973/79 F500/800 / 1978 F100/350 & Bronco before serial number BA0,001 / Myriad 1960/70's Passenger Cars.
1,054 (!!) are available NOS from Ford Dealers/obsolete parts vendors and repro parts sellers have them as well.
When these bushings "go away" the 90 degree ends of the rod begin to bend, eventually snap off, not pleasant! The rod is obsolete...almost as hard to find NOS as Jimmy Hoffa.
2) C1AA-7543-A .. Equalizer Bar Nylon Bushing / Available from Ford.
The Memphis TN Ford parts depot has 375 of the little darlin's, another 1,778 (!!) are available from Ford Dealers/obsolete parts vendors and repop sellers also have them.
MSRP each: $5.15 // FTE sponsor PARTSGUYED.COM price each: $3.71.
With a M/T, there are 2 nylon bushings that ride on the clutch pedals shaft, 2 more fit into the brake pedal that rides on the clutch pedals shaft.
If a 2WD, there are only 2 .. fit into the brake pedal / NOTE: Don listed basic part # 2474 because that's what the catalog pic (Illustration Section 75, page 25) shows, but that's the wrong number.
There are two types of these bushings and the parts catalog applications are very fuzzy, making them a b!tch to look up.
Compare what you have with the following:
B7C-2461-A .. Brake/Clutch Pedal Nylon Bushing-15/16" long / Available from Ford.
MSRP each: $2.50 // FTE sponsor PARTSGUYED.COM price each: $1.80.
B7AZ-2471-B (replaced B7AZ-2471-A) .. Brake/Clutch Pedal Nylon Bushing-Split-5/8" long / Available from Ford.
MSRP each: $1.86 // FTE sponsor PARTSGUYED.COM price each: $1.20.
The master cylinder (P/B booster) push rod attaches to the brake pedal with a thru bolt, uses 1 nylon bushing.
C1TT-2A309-A / Obsolete
26 available NOS from Ford Dealers/obsolete parts vendors.
