VIN question
Old Sep 14, 2011 | 06:37 PM
jwmayfield's Avatar
jwmayfield
Question VIN question
both my title and the county say my truck is a 1978 F250 but everything on truck including door plate says it is a 1 ton F350.
Old Sep 14, 2011 | 06:41 PM
raytasch's Avatar
raytasch
Believe Nothing
The important thing is the serial number on the frame of the truck and the VIN listed on the title match.
Old Sep 14, 2011 | 06:55 PM
jwmayfield's Avatar
jwmayfield
yes everything matches. Now I do know it was a special order for a small town fire department.
Old Sep 14, 2011 | 07:15 PM
mikeo0o0o0's Avatar
mikeo0o0o0
For a 2WD an F250 VIN should start F25 a 350 Should start with F35. Post your truck's VIN and we can decode it for you.
Old Sep 14, 2011 | 07:31 PM
jwmayfield's Avatar
jwmayfield
It does start F25. but from what I have been told some special order 350's started out as 250s.
Old Sep 14, 2011 | 08:43 PM
mark a.'s Avatar
mark a.
Is it a 4x4 ? The first your for the F-350 4x4 was '79.
Old Sep 14, 2011 | 08:46 PM
jwmayfield's Avatar
jwmayfield
no it is a 2x4
Old Sep 15, 2011 | 02:27 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Whoever told you that horse dung had absolutely no friggen clue, because there is no such thing!
Compare the VIN on the registration with the VIN on the Warranty Plate to see if they match.
People replaced damaged left doors with used doors. 99% of the time, they did not install the original Warranty Plate on the replaced door.
How can you tell the outward appearance differences between an F250 2WD and an F350 with SRW? The emblems are different, one sez F250, t'other sez F350.
And, emblems can be swapped around. Look for the hidden frame VIN, then post what it is.
If a truck is a domestic special order, it will have a 6 digit DSO code. If not, the DSO code is 2 digits.
The DSO code will be found on the 3rd line of the Warranty Plate.
F250 2WD Series codes (first 3 digits of the VIN): F25 = F250 2WD Pickup / F27 = F250 2WD Cab & Chassis / X25 = F250 2WD Super Cab Pickup / X27 = F250 2WD Super Cab Cab & Chassis.
Old Sep 15, 2011 | 06:47 AM
jwmayfield's Avatar
jwmayfield
I find it very hard to believe someone would go thru the trouble of changing out all 3 emblems with F350 emblems and they are far from new.
Old Sep 15, 2011 | 10:26 AM
NumberDummy
I find it very hard to believe that you would assume this is an F350 since the VIN on the registration begins with F25.
There are only two emblems on the exterior of these trucks, where is the 3rd one? What do they look like? 1973/76 is one type, 1977/79 is another.
Where are they located?
Old Sep 15, 2011 | 10:34 AM
jwmayfield's Avatar
jwmayfield
Well I meant 2. Plus the vacume diagram is for F350.
Old Sep 15, 2011 | 11:51 AM
NumberDummy
As I recall, the vacuum diagram is on the left valve cover...is the cover original to the truck? Is the engine original to the truck?
It's also possible that the wrong diagram was installed...how about posting a pic of the puppy.
If you want the facts, contact martiauto.com. Marti has ALL the original records for 1967/79 FoMoCo vehicles, Ford has none of it any longer.
In the late 1980's, Ford was planning to THROW AWAY these records. Kevin Marti, a 'Mustang nut' in Phoenix AZ found out about Ford's plan and got ALL of it.
Old Sep 15, 2011 | 12:35 PM
crazyeddie's Avatar
crazyeddie
Couldn't he also check the axle ID tag and see if it corresponds with the axle code on the door plate? Or do the same with the trans code? If the door was replaced and the tag not swapped, he might find a hiccup in the numbers somewhere. Even the casting numbers on the block?
Old Sep 15, 2011 | 12:53 PM
jwmayfield's Avatar
jwmayfield
Ok alvin fire department owned truck till 1984. Then the retiring fire chief purchased from city and after he died his son owned until the guy I bought it from bought it. No wrecks.
Old Sep 15, 2011 | 05:41 PM
NumberDummy
If an A/T, Ford used the SAME trans code for all A/T's used in 1965/78 F100/350's: G
One had to know which trans was used with what engine.
The T-18 4 speed trans code is the same 1965/79: F
The NP435 trans code is the same 1966/79: A
The 3 on the tree M/T code is the same 1966/79: C
Casting numbers on engine blocks are worthless for ID'ing the size of the engine (except 1979 460's w/a D9TE-6015-AB number) or what it came from.
Casting numbers are foundry marks, cannot be cross referenced to Ford part numbers.
The Ford ID tags on Dana axles are under one a the bolts that retain the inspection cover to the housing. Today, many are MIA.
The Warranty Plate AXLE codes could be the same 1973/79, but don't count on it, cuz Ford changed the codes more often than women change their minds!
Ditto COLOR codes.
Doesn't really matter if the Warranty Plate is original to the truck...or not, since the VIN on the registration begins with F25.
But, what the OP hasn't done is...compare the VIN on the registration with the VIN on the Warranty Plate and the hidden frame VIN to see if they all match.
