Vibration while coasting in neutral ????
Old Sep 14, 2011 | 05:44 PM
Gomer1's Avatar
Gomer1
Hi guys Heres the symptom... While driving down the road at 50 mph or faster if I press in the clutch to coast or shift to neutRAL to coast down a hill I get a significant vibration in the driveline... but the second I put back into gear and /or let the clutch back out vibtation goes away. I am hoping this is something simple, have any of you had this problem??? the only thing I noticed by looking underneith is a small drip where the driveshaft comes out of the transfer case. please help!!
Old Sep 14, 2011 | 08:13 PM
Gomer1's Avatar
Gomer1
Forgot to mention earlier, it make some noise from undernieth almost a rattle??? while engine running parkes in neutral
Old Sep 14, 2011 | 08:32 PM
Volvo92906's Avatar
Volvo92906
U-Joints maybe? Assuming while driving in gear the joints are under load and being torqued on so all is well. When you push in the clutch and its in neutral, the torque lets off on the driveshaft and you get a vibration.
Not saying this is the problem... Just a theory.
As for being parked and in neutral... could be the catalytic converter maybe. Mine rattles too.
Old Sep 14, 2011 | 08:36 PM
Gomer1's Avatar
Gomer1
That what I thought too, but they are OK , thanks for the input, I am thinking possible an shaft output bearinbg or something
SHOpar
Jun 17, 2010 09:31 AM
gmills
Nov 24, 2008 10:34 PM
jmsupafly
Dec 1, 2006 07:16 PM
fairlaniac
Nov 14, 2006 01:40 PM
fordman_302
Mar 5, 2001 08:11 PM
