I got a 96 f150 302 auto. I noticed a slight antifreeze leak but cant seem to find it. When I look at the inside of the fan shroud there is a puddle of antifreeze laying on the shroud where it meets the radiator on the passenger side. The same side as drain for radiator and the drain looks fine.. Any Ideas of how to locate it or where it is from..
I went to Autozone and rented it for 75.00 and when I returned it they gave me all my money back.. This is really the way to go they lend alot of different tools... You get to use it free unless you break it...
I found mine also it was the radiator.also my fan clutch is going out so I am going to do that also. Mine was also leaking from the passenger side also my water pump weep hole was bone dry I even stuck a Q-tip in it to make sure, it was very dusty my new one is from Oriellys auto parts but it is a bit larger (depth)so the shroud will cover more of the blades I plan to do it this weekend should take about two three hours including clean up
Donavan
I pulled my radiator today and took it to my local radiator repair shop. It was leaking on the passenger side where the tank hooks to the core. He fixed it and tightened both side tanks and cleaned out the core for 45.00. I thought that was pretty reasonable compared to a new one.... He guaranteed it to work so I am leak free so far.... The radiator is very easy to take out it went very fast...
I didi it in about 2.5 hours you are right it was pretty easy.I was almostnervous because it was too easy.My rad was too leaking the same way you desribed.I went for the new one since I am replacing most the vital parts due to age or just plain being worn out.
Donavan
