Fuel pressure under load?
Old Sep 12, 2011 | 09:12 PM
Butch(OH)'s Avatar
Butch(OH)
Still working with some drivability issues and other quirks in my 97. Decided to install a fuel pressure gauge where I could see it while driving. Truck has 55lbs (middle of needle bounce) at idle and 60 when you bring the RPMs up above idle. Going down the road at 1500 to 2000 RPM in 4th gear if I mash it the pressure drops to 40, if I set the chip up to the first notch (heavy tow, cant remember the HP), it drops to 30, if I set the chip to the next higher (I think 50HP) higher it drops to 20. Truck has Rosewood 1s and a T-S chip with PHP tunes that are pretty aggressive and a S-D pump. Do these pressures sound OK or not? Fuel sytem is stock, filter is new, gauge is plumbed in at schrader valve. I plumbed a clear line into the return line at the filter to check for bubbles and there are none. Sorry if this is often posted I couldn't find it via search.
Old Sep 13, 2011 | 08:18 AM
84-250's Avatar
84-250
All I can say is that with a new mech pump, I can drop fuel pressure down to 30 from 65 with stage 1 and the hottest tune. I asked this same question a month ago and no one could answer if dropping fuel pressure this low would hurt injectors or lose power
Old Sep 13, 2011 | 09:38 AM
superduty4x4's Avatar
superduty4x4
You're a little low on pressure, you might try the FPR shim.
Old Sep 13, 2011 | 04:41 PM
Butch(OH)'s Avatar
Butch(OH)
Thanks guys, at least I know if it's in the ballpark. I'll shim it up a bit.
Old Sep 14, 2011 | 06:12 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
I don't think you'll cause much damage with pressure that low, but you are certainly loosing power.
You want a rock-steady 65 psi.
I dynoed years back changing fuel pressures and 10 psi under 65 lost like 10 hp, and 10 psi over 65 lost about 10 hp. You want to be right at 65 allthe time.
So if you're dropping more than that you need to get more fuel pumping.
If it's 50 at idle, shim to 65 and re-test. It should at least bring your low numbers up a bit.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
1994F2507.3L
Oct 14, 2016 03:58 PM
iverger
Jan 18, 2015 05:50 PM
super10brss
Jan 3, 2012 03:19 PM
Jeepincj7
Dec 24, 2011 03:47 PM
fordgallor
18
Jun 4, 2006 05:51 PM
