fpr shim
Old May 9, 2006 | 12:51 AM
fordgallor's Avatar
fordgallor
fpr shim
i was going to shim my fuel pressure regulator today, so i put my psi gauge on the schrader valve and to my suprise when i reved the engine to around 2000 rpm the gauge wint to 70ish psi. i know for sure it has nothing done to it since factory. so why would it have this much psi??? or am i doing something wrong??? i have a chip but that has nothing to do with this does it??? thanks
Old May 9, 2006 | 01:03 AM
1997F-350's Avatar
1997F-350
your truck a cali truck?
ideal pressure is 75 psi. most peoples truck are lower than this when checked thus the fpr shim. if yours is good no need to shim leave alone.
Old May 9, 2006 | 01:12 AM
ForemanES's Avatar
ForemanES
I get 65 psi at idle.
Do rpms increase pressure?
Old May 9, 2006 | 01:14 AM
1997F-350's Avatar
1997F-350
no i dont think so just the volume of fuel.
Old May 9, 2006 | 01:20 AM
ForemanES's Avatar
ForemanES
Wont stock trucks (not Ca) have 40-50 psi?
fordgallor sounds like you have a Ca truck (with split shot injectors)
Old May 9, 2006 | 01:21 AM
1997F-350's Avatar
1997F-350
mine had 48. you could be right.
Old May 9, 2006 | 01:36 AM
powerstroked162's Avatar
powerstroked162
i was at 52psi before shim, now im runnin 82psi!
Old May 9, 2006 | 01:39 AM
ForemanES's Avatar
ForemanES
Did you use a bb or a screw? Did that much pressure help smooth out the idle?
Old May 9, 2006 | 01:46 AM
powerstroked162
i used the 19-42 bolt or somethin along those lines. got the idea off of Baz's page. Anywho, i wouldn't recomend going above 75psi. It does help out idle roughness, however i had to modify the fuel bowl assembly as i blew the original one to pieces on the highway doin 70mph. Not a good situation. shot the FPR schrader valve and plunger bolt and assembly right off the bowl. takin half the fpr and fuel bowl with it. so i modified it alittle bit
Old May 9, 2006 | 12:02 PM
1996pwrstrk's Avatar
1996pwrstrk
I checked mine the other day it was bouncing between 52 to 68 I was going to shim it and decided not too.
Dave
Old May 9, 2006 | 01:54 PM
1969fordguy's Avatar
1969fordguy
What kind of gauge does one use to read the fuel pressure? The schrader valve looks like one in a tire...
Old May 9, 2006 | 02:25 PM
1997F-350's Avatar
1997F-350
exactly.
Old May 9, 2006 | 02:42 PM
fordgallor's Avatar
fordgallor
what are split shot inj. and how can i tell if it is a ca engine. the truck was bought new in missouri and has been owned by 1 other person besides myself. he never touched it.
Old May 9, 2006 | 03:29 PM
ForemanES's Avatar
ForemanES
If it is a cali truck it has larger split shot injectors (~120cc) compared to 49 state trucks with single shot (98cc).
"Split-shot injectors were originally installed on 1996 and 97 model/year trucks with California emissions, and are used in engines from 98.5 on. These injectors prolong the injection time to decrease emissions without reducing power"
I think you can use you VIN # to find out if it has Cali emmision
Old May 9, 2006 | 05:28 PM
1997F-350's Avatar
1997F-350
hey look in here. the first 3 pics should help you out this is my dads ca truck.
first pic is a ca emissions sticker on the under side of the hood where it latches.
second pic is the teal valve cover sticker.
third pic is the fuel dampener under the pedistal on the back of the fuel pump it says bosch on it.
another way is your pcm code.
i highly doubt you have one if you bought it from original owner in the midwest.
