Sponsored by: Kumho
2003 Tire Upgrades????
Old Apr 5, 2003 | 02:07 PM
Brian429's Avatar
Brian429
Question 2003 Tire Upgrades????
I have a 2003 F150 with stock tires (255/70Rx16) and no lift kit. I want to go with a little more aggresize tires than I can get from factory. But my question is I want to get a little larger tires too, I think the "stockers" just look undersized on the truck. I can't get a honest answer from any local tire dealers, everyone gives me a different answer. Anyone out there upsize their tires, and is so, how big did you go. Keep in mind I don't plan on making any lifts to the body, want to keep in fairly stock looking.
FORDS RULE!!!!!!!!
Old Apr 8, 2003 | 11:03 PM
fordmudrunner2020's Avatar
fordmudrunner2020
You could probably fit 1 to 4 inch bigger tires maybe even bigger. It depends on if they rub or not. Also since it is IFS fron suspension you might not be able to fit as big of tires with out a lift which is big$$$ for IFS. A nice tire that we have on one of our trucks is the BFG AT it performs OK off-road and is great for high way.
Old Apr 9, 2003 | 07:59 AM
superrangerman2002's Avatar
superrangerman2002
for the 97-01 150's supposedly the largest tire you can run with out a lift is a 285/75r16.
How much difference between a 03' and a 01 150, I'm not sure.
Old Apr 9, 2003 | 10:46 AM
72f100's Avatar
72f100
I've seen several 97- F-150's w/ 285-75's and they look really good. The tires look just big enough w/o looking too big for the truck. I would suggest a set of 285-75 R16's BFG AT's. They should look good and last you quite a while.
Old Apr 9, 2003 | 12:58 PM
Troy24's Avatar
Troy24
I have a 99 f150 ext with 305-70-16 Goodyear Wrangler MTR's on it, looks real good and does not rub,no lift on it yet.
Nightrain
1983 - 2012 Ranger & B-Series
Apr 20, 2009 09:28 AM
gunpowder_250
Oct 14, 2008 03:07 PM
kjd2121
1978 - 1996 Big Bronco
21
Jul 21, 2006 08:35 AM
jlcote
Sep 5, 2005 05:05 PM
Rambo
May 17, 2004 01:27 PM
