New excursion owner
Old Sep 12, 2011 | 04:11 PM
Shamu's Avatar
Shamu
New excursion owner
Getting ready to buy a 2000 x with 141k on the clock. 4x4 with the v10.
Truck has a few problems. The biggest is the rear springs. It had a rear tire blow out at sometime and I believe caused a excessive spring warp because the truck drives down the road a little sideways. He current owner and friend had a mechanic look at it an came to the same conclusion. Abs light in on and throwing a b1155 & b1230 code. Check engine light is also on throwing a p0500, p0171, p0174 codes. Engine is running lean and has a problem with it's vehicle speed sensor.
We have a 2000 budget to fix/modify. With another few thousand a little down the road.
It's the wife's truck and she has a list of wants.
2-3" of lift with at least 33" tires.
Dual exhaust
Recover leather seats.
2003 style headlight/hids
F250 grill
Where I need help is with the lift & spring replacement choices.
Old Sep 12, 2011 | 05:05 PM
jh818's Avatar
jh818
What's the asking price?
Old Sep 12, 2011 | 05:55 PM
Shamu's Avatar
Shamu
$5000. Other than the things listed above the truck is mint.
Old Sep 12, 2011 | 09:12 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
You've come to the right place...
You should be able to get it for $4,500 or so unless the dug their heels in at $5,000.
Regardless, I say go for it...this is the perfect place for you and your to be new truck...
Btw, limited ot xlt?
Old Sep 12, 2011 | 09:41 PM
Shamu's Avatar
Shamu
Limited.
Buying it from a friend. He needs the $ and is a good friend. I'm happy to pay $5k for it.
Old Sep 13, 2011 | 02:26 AM
Trevor.801's Avatar
Trevor.801
Pics when you get it!
Old Sep 13, 2011 | 05:42 AM
Shamu's Avatar
Shamu
Anyone have any suggestions on the direction to go with the springs?
Thought about swapping out with some f250 springs but there is so many codes out there. And will they net me enough height to clear 33" tires? Or should I just go with a lift kit that replaces all four springs? This will be my wife's dd with little off road and no towing. Any one recommend a kit?
Planning on the rear sway bar and new shocks as we'll as a standard "tune up" as well
Old Sep 13, 2011 | 06:11 AM
Toreador_Diesel
Originally Posted by Shamu
Limited.
Nice! It's always good to help out a friend in need...
Depending on how much lift you want, The V/X code or V/B code springs may be what you need. With either you'll be able to clear 305/70/16s without issue. You can already clear them as it stands, but you can do it better with either set of springs.
These springs will also cost considerably less than a lift kit and give you the same effect without modifying steering components.
Stewart_H is THE go to guy when it comes to this mod as he's done a ton of research and even went so far as to document it here on FTE. I'll send him this way.
Congrats on your new truck!
Old Sep 13, 2011 | 04:30 PM
Shamu's Avatar
Shamu
Thanks. I've been reading a ton on this subject including Stewarts posts.
I'll get pics up this weekend. I'm out of town till Friday.
Looking at tunes as well to improve mpg.
Old Sep 13, 2011 | 04:51 PM
leno182's Avatar
leno182
your speed sensor
it is probably trigering your abs light 2 come on replace it and it should go away.
Old Sep 17, 2011 | 07:53 PM
Shamu's Avatar
Shamu
One more at the desired height compared to her current ride.
And one of the driver side rear spring. The tire blew out on a po(not my friend he one before) you can see the leafs all out of alignment.
The wife decided on a 4" lift. We put the truck on jack stands at +2 and +4 to she how easy/hard it would be getting in and out.
What I'm looking for now is advise on how to lift it. I'd like to keep the budget to under a $1000. I know I'll need new rear springs. Should I try to piece something together or look at a kit?
Old Sep 18, 2011 | 08:41 AM
Shamu's Avatar
Shamu
Ok did some online window shopping.
Pro-comp front spring 22210: $124.29 each
Pro-comp rear spring 22415: $134.95 each
This totals to $518.48 for just springs
Zone adjustable track bar: $99.99
Pro-comp drop pitman arm: $89.37
Pro-comp U-bolt: $48.34 each/2 sets needed
This totals to $804 before shocks
Anyone have any suggestions on shocks?
Old Sep 18, 2011 | 09:35 AM
Red Ex's Avatar
Red Ex
For shocks RS9000 or custom valves Bilsteins. I have the Bilsteins and really like them.
For a lift it sounds like you are on track with your budget. Some of the lifts that say 4" end up being 6" on the Ex as it is 2" lower than a F250 to start with. If you lift 6" the 33's will look to small. Most aftermarket spring lifts ride extremely stiff. Stiffer than I or especially DW would tolerate.
We did a V/mod B spring upgrade with 4.5" spring hangers/6" blocks and the ride is amazing both unloaded or loaded towing at maximum capacity. For the lift we went with ICON components and have been extremely satisfied. If you go 6" you may get driveline vibrations. I think you will also need to extend the sway bar end links.
Old Sep 18, 2011 | 10:34 AM
Toreador_Diesel
Bilsteins.
You can get them from Autozone WITH a lifetime warranty. They come in stock and the 5100 series lifted applications. I have 5100s all around and love them....
Old Sep 18, 2011 | 12:43 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
where are these deals when I am looking? I've been trying to find an Excursion since I first saw one. Never found one for a good price though.
nice rig
