which tranny do i have?
Old Sep 12, 2011 | 11:57 AM
86scotty's Avatar
86scotty
02 E350 extended, 5.4l. Is it printed on the transmission somewhere? I called the dealer (without the vin) one day and just by year and model he said it had an E40D, but it just doesn't shift like one to me. Do i need to call back with VIN # or is there an easier way i can tell like it being printed somewhere?
thx
Old Sep 12, 2011 | 04:50 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's on the data tag in the driver's door opening. Under "TR" is either a "U" or an "E." "U" means 4R70W and "E" means 4R100. Both were used in the 5.4L E series.
Old Sep 12, 2011 | 06:37 PM
86scotty's Avatar
86scotty
Thx! I knew there probably had to be a code somewhere. Is one heavier or better than the other?
Old Sep 12, 2011 | 10:07 PM
Mark Kovalsky
The 4R100 is heavier duty. Either one is strong enough to last with a 5.4L.
Old Sep 12, 2011 | 10:17 PM
86scotty's Avatar
86scotty
Thanks Mark!
Old Sep 14, 2011 | 06:33 PM
carrfamilynj's Avatar
carrfamilynj
The door sticker on my '08 E350 5.4 says Trans Code Q. Which one is that?
Old Sep 16, 2011 | 06:51 PM
carrfamilynj
What am I, chopped liver?
Old Sep 16, 2011 | 08:33 PM
Mark Kovalsky
It's a 4R75E, or a 4R70E, or a 4R75W. Since I didn't know I didn't answer. But you want an answer, that's the best I could do.
Or maybe this would help: The first link doesn't have the answer. Go to the second. It's called "trying to figure out what transmission I have."
Let me google that for you
Old Sep 17, 2011 | 03:48 PM
CAPTAIN DIESEL's Avatar
CAPTAIN DIESEL
u deff have a 4r100
Old Sep 17, 2011 | 04:17 PM
toeout's Avatar
toeout
Go to www.fordparts.com , put in your VIN and on top of the page it gives you your model, engine and transmission.
Old Sep 17, 2011 | 04:39 PM
Mark Kovalsky
Originally Posted by CAPTAIN DIESEL
u deff have a 4r100
If you were referring to the above post you're wrong. The last year the 4r100 trans was built was 2004. It was long gone before his 2008 E350 was built.
Model: 4R75E
Type: Four speed, Rear wheel drive, and 75(x10)lbs of torque
Years: '04-'07 F-150
Engines: 5.4L
Display: PRN(D)21 w/ overdrive lockout switch
Fluid: Mercon V
Ratios:
1st 2.84:1
2nd 1.55:1
3rd 1.00:1
4th 0.70:1
Reverse 2.32:1
Trans code: B ('04-'05), Q ('06+), F ('06+ Mark LT)
Old Sep 17, 2011 | 04:43 PM
carrfamilynj
According to the fordparts.com site, it has a 4R75W. So I guess the TransGo 4R100 reprogramming kit I got will have to go back. Looks like they don't even make one for the 4R75W.
matt16875
Aug 21, 2007 07:48 AM
lvengineer
1997 - 2003 F150
Apr 10, 2005 02:59 PM
SHUSTANG
1997 - 2003 F150
Jan 14, 2005 08:17 AM
pizalm
Jul 19, 2004 11:03 AM
bumblefoot
Nov 12, 2002 12:02 AM
