2003 Econoline - is the flasher relay in turnsignal switch assembly?
I have a 2003 E-350 and the turnsignals started acting up yesterday. When you engage the turnsignal stalk, the lights flash couple of times and then stop. Re-engaging the the stalk makes it work again, but you can get no flashes or couple of flashes or many flashes ( completely random ). This the same for left and right and hazards.
So this looks like electronics related, like flasher relay. From the schematics it looks like everything flasher related is built into the turnsignal switch assembly and changing it out should solve my problems.
This switch:2003 Ford E-350 - Turn Signal Switch | FordParts.com
I just wanted a conformation from somebody knowledgeable that this is indeed the case and the flasher relay is not somewhere else. Thanks in advance.
cuttn4fun
03-21-2014 09:30 AM
DPDISXR4Ti
04-21-2012 07:27 AM
