Won't let go
Old Sep 11, 2011 | 10:48 AM
merlynr's Avatar
merlynr
Won't let go
Trying to remove a 390 from a 73 1 ton w 4sp(np435) and I can't get it. I took the bolts loose from tranny to bellhousing,disc the clutch arm and everything in engine bay is disconnected. I have seperation at the tranny of less than an inch. Then I removed the starter and all the bellhousing bolts and pried it apart off the alignment pins with about an inch of seperation. Now i have a gap between eng-bellh and bell-tranny but it still won't come free. Is it the throwout bearing,clutch? Gonna unbolt the press. plate tomorrow. Rain and frustration stopped me yesterday
Old Sep 11, 2011 | 11:25 AM
brian1080's Avatar
brian1080
did you remove the bolts from the dust shield under the rear of the engine?
Old Sep 11, 2011 | 06:03 PM
merlynr's Avatar
merlynr
Yes, that's the first thing I took off
Old Sep 11, 2011 | 07:05 PM
evam350's Avatar
evam350
Do you have the front of the transmission supported?
Old Sep 12, 2011 | 08:52 AM
merlynr's Avatar
merlynr
Yes and have been jacking up and down a little along with raising and lowering the engine. Gonnna go out in a few and take the pressure plate bolts out and see what happens.
Old Sep 12, 2011 | 09:44 AM
Lil Red Sled's Avatar
Lil Red Sled
Is it a 4x4? If so make sure the shifter is un bolted and its not hiting anything while your trying to pull it out.
Old Sep 12, 2011 | 01:02 PM
merlynr's Avatar
merlynr
When I took the last bolt out of the pressure plate it kind of moved and when I lifted the engine a little it swung free with no prying. The pilot bearing had at least two ***** missing
ekm71f100
Dec 29, 2012 11:55 PM
Greg5OH
May 16, 2012 11:33 AM
blkfordtruck
1978 - 1996 Big Bronco
Aug 4, 2011 09:02 AM
RJCarp2
Feb 10, 2007 06:04 PM
Phreaq
Mar 28, 2005 09:06 PM
