Help please!
Old Dec 29, 2012 | 02:17 PM
ekm71f100's Avatar
ekm71f100
Help please!
I have a 95 f150 with a 5 speed, motor blew so I'm pulling it out, all the bolts are off the tranny and it has about a 1/2 inch gap between the bell housing and block, I can spin the tranny but it will not let loose, I've tried prying it apart but it will not give! Any ideas?
Old Dec 29, 2012 | 04:48 PM
88n94's Avatar
88n94
If you're sure you have all the bolts OUT. Did you unbolt the pressure plate bolts from the flywheel? That's the only way I will pull an engine while leaving the transmission in place. I'm assuming you can still turn the engine, otherwise you couldn't get the top pressure plate bolts out.
Old Dec 29, 2012 | 10:45 PM
UNTAMND's Avatar
UNTAMND
Two starter bolts
6 bellhousing bolts
2-3 lower block plate bolts (in front of bellhousing)
Seems to me you need to put more anger into removing the two.
Old Dec 29, 2012 | 11:55 PM
Puddy's Avatar
Puddy
Comment was regarding an auto, sry
Bearhead
Aug 4, 2015 11:30 AM
cabloom300
Aug 12, 2010 06:58 PM
slayerman54
Apr 19, 2010 04:04 PM
ROKRAWL
Nov 18, 2003 11:10 AM
wvmiller_68
Mar 16, 2003 11:16 AM
