Upper injector retaining bolt?
Old Sep 10, 2011 | 06:54 PM
j250hd's Avatar
j250hd
Do any of you guys know the proper torque for it?
Old Sep 10, 2011 | 06:57 PM
pjwoolw's Avatar
pjwoolw
Fuel Injector Retaining Bolt 12 Nm
Oil Relfector Retaining Bolt 12 Nm
Oil Rail Drain Plugs 6 Nm
Valve Cover Bolts 11 Nm
Link to conversion chart.
Old Sep 10, 2011 | 07:10 PM
j250hd's Avatar
j250hd
Does this go for the collar bolt as well?
Old Sep 10, 2011 | 07:40 PM
pjwoolw's Avatar
pjwoolw
Here is a couple of diagrams. Torque values are the same for both the injector retaining bolt and shoulder bolt.
Old Sep 10, 2011 | 09:54 PM
F350-6's Avatar
F350-6
It's 120 in-lbs, but the hold down plate is slotted to slip over the upper bolt so it doesn't need to be removed. The plate is also a fulcrum design so torquing down the lower bolt will tighten down the injector properly.
The only way you can tighten the upper bolt after the injector is installed is to remove the injector solenoid (unless you've got some really fancy tools), but luckily, the lower one is all you really need to worry about unless you've removed the upper bolt.
Old Sep 10, 2011 | 11:12 PM
j250hd's Avatar
j250hd
Thanks guys! Had to replace the injector cups that's why they were out.
landmobile
29
Oct 27, 2017 12:19 AM
xtremexj
Aug 12, 2013 03:55 PM
damons
Aug 23, 2011 12:51 AM
oldbird1965
Feb 10, 2008 05:47 PM
tmehrkam
Modular V10 (6.8l)
23
Nov 22, 2005 01:26 PM
