lifter bleeding procedure
Old Apr 4, 2003 | 10:08 PM
jbulson's Avatar
jbulson
What is the proper way to bench bleed new lifters?
Old Apr 4, 2003 | 11:44 PM
macguyver's Avatar
macguyver
I think you mean you want to pump them up. The recommended procedure is to place them upright submerged in oil and using a pushrod cycle the plunger until you get resistance.
However, what has worked the best for me is I take my oil can with the pump lever filled with the oil I use for assembly and pump it into the small oil hole on the side of the lifter. I have modified the spout on my can with a slight concave on the tip to fit the contour of the lifter for a better seal. Or a small hose fastened to the end also works.
It's probably overkill 'cuz if (? when) you prelube the engine and you do it before the valves are adjusted (leave them loose) the oiling system will pump up the lifters.
Just my 2¢
Greg
Old Apr 5, 2003 | 08:26 AM
jbulson's Avatar
jbulson
Great!!! Thanks for the advise, Ill pump them up the old fashoned way.
DutchmanAZ
Garage & Workshop
Sep 10, 2014 06:17 AM
timbersteel
17
Jul 7, 2014 10:17 PM
gudoldboy
Oil & Lubrication
Sep 9, 2003 10:22 AM
turbojeff
Mar 28, 2002 10:42 PM
