Some 400 questions
Old Apr 4, 2003 | 09:23 PM
73Galaxie's Avatar
73Galaxie
Some 400 questions
I've enjoyed reading the threads in this forum, it's about the only place that I can find any information about the 400 in my Galaxie. I have a remanufactured 400 bored .030 over with stock compression, decked, balanced and line honed with an aftermarket Melling cam with 204/214 duration at .050 lift(I guess it's a RV cam with around 260 total duration), Edelbrock Performer (non-egr) manifold and a 1406 Edel 600 cfm carb. I have dual exhaut with 21/4 diameter pipes and turbo mufflers as well.
I need to replace the carb, the throttle shaft is worn and visibly moves when I move the throttle and the idle won't stay where set it. The choke no longer works, and since I'm not working right now, the only carb I can afford is a rebuilt 4300 4 bbl, it's about $75 cheaper.
So, will the 4300 work on my Performer with that thin adapter plate? Do I need to re-jet the carb? And...what CFM is it? Would I see a mileage increase compared with the Edel carb?
The other question is that when the motor was put into my car, the mechanic used the stock valley pan intake gasket. I found out later when I got an edelbrock catalog that edelbrock specifically stated that they don't recommend the stock gasket and I should use aftermarket Fel-Pros. Why is that and should I get the manifold taken off and redone correctly?
Lastly, does anyone have an engine analyzer software program? I'd like to see how much hp and torque I have.
Old Apr 6, 2003 | 07:55 AM
snowfighter's Avatar
snowfighter
Some 400 questions
I think you can buy parts for your carb, or you can send to elderbrock for a rebuild either would be cheaper than a new carb.
Old Apr 6, 2003 | 12:27 PM
Bill_Beyer's Avatar
Bill_Beyer
Some 400 questions
The instructions I got with my E'brock Performer 400-EGR state specifically to use the OEM type gaskets as opposed to "race type" gaskets. The only difference was that they recommend using RTV instead of the end seals.
Old Apr 6, 2003 | 04:09 PM
RUFUS79's Avatar
RUFUS79
Some 400 questions
I do but need more info about your engine
1- actual comperssion
2- cam lift (example int. .467, ex. .500)
3- is your cam timed stright up or factory 4 degrees retarded
after I get that then I can tell you just about what your getting. I mostly need more info on your cam.
Old Apr 6, 2003 | 05:43 PM
RUFUS79's Avatar
RUFUS79
Some 400 questions
here is what I came up with,
cam-204, 214 @0.50
lift 493in, 502ex
600 cfm carb
8:1 compression
dual plane intake
406 ft lbs @2000 rpm
241 horsepower@4000 rpm
now that is with small tube headers with mufflers. Also your compression might be a little higher because the block was decked so this will give you a little understanding where you are. its a pretty good streetable set up to me.
Old Apr 7, 2003 | 08:42 AM
73Galaxie's Avatar
73Galaxie
Some 400 questions
Well, that's good news about the intake, I'll leave it alone. It doesn't leak or anything, I was just wondering about the long-term consequences, I paid a lot for my motor, don't wanna fry it too quickly!
I'll call Edelbrock's 800 number and see how much a rebuild is.
Those numbers sound great to me, after all, torque is the main factor in acceleration (0-60), horsepower determines how fast you can eventually go (i.e. top end speed). It feels MUCH stronger than when the motor was stock. The compression is 8.4 : 1 plus it's probably a little higher because of the decking and the heads being leveled/shaved so I figure it's somewhere near 8.75 or 9. The cam is timed straight up at 0. The lift specs are .493 int. and .502 exh. It doesn't have headers, but I could tell a big difference after I lost the stock muffler and single exhaust. The only headers I found are Hedman Huslers and they are pretty pricey, $484.32 plus shipping . I think the tube size is too big, it's 1 7/8 inches, and I'd bet they'd kill my low end power. I need to take the manifolds off and get in there with a grinder and smooth things out a little. I'm used to $100 headers, had them on my 69 F-100 and my Cougar and they worked just fine for me.
Old Apr 8, 2003 | 03:11 AM
GT40man's Avatar
GT40man
Some 400 questions
Vendor: Dynomax Performance Exhaust
Product Line: Dynomax Blackjack Painted Headers
Material: Steel
Finish: Painted
Header performance at a moderate price.
Ford/Mercury: 1970-74 351C-2V, Fairlane, Mustang; 1970-73 Ranchero/Torino; 1970-74 Cougar, Cyclone, Montego, 1 3/4 in. primary tubes, 3 in. collectors, painted, headers
Dynomax headers are computer bent and leak tested, have die-cut exhaust port flanges, and machine formed and hand welded primary tube ends for unrestricted exhaust flow. They come with a black painted finish.
Sold as a pair.
these are $110 at summit
74 F350 SCS
16
Oct 15, 2012 09:53 PM
OrangeBeast78
Jul 11, 2011 03:20 PM
lasthighboy
Oct 21, 2009 10:24 PM
mlevario99
Feb 6, 2008 11:13 PM
johaner78
Dec 7, 2005 12:26 PM
