WHAT WENT WRONG?????
Old Sep 8, 2011 | 04:55 PM
sayala37's Avatar
sayala37
I have an 2001 Expy V8 5.4L I had my ac compressor go out so I installed a bypass pulley this morning. Not too bad of a job but once I started my truck back up I put in in drive and the whole truck shook and puttered when I gave it gas. Put the code reader and I got 7 different faults. 0743,0755,1747,0443,1451,0135,0155,. It drove fine this morning but I have been needing to change it and finally did. My thought is, the lines that were connected to the old compressor are not capped off. I just tied them up. Could or are these vaccuum lines and they're pulling air in?? Like I said I've never had any issues with my tranny and it was fine up until I changed out the compressor?? Help Please!
Old Sep 8, 2011 | 06:13 PM
alloro's Avatar
alloro
I would say you knocked a vacuum line loose (or cracked one) while you were in there working.
Old Sep 8, 2011 | 06:49 PM
sayala37's Avatar
sayala37
That's my thought too, but I'mnot sure what vacuum line(s) it could be. I disconnected the hoses from the compressor and pulled it out from the front??? I will need to look around some more, just not sure there were many lines in the way.
Old Sep 8, 2011 | 07:26 PM
LeeLeadingham's Avatar
LeeLeadingham
I recently done the ac bypass pulley on mine the other day.
Didn't have a problem.
I'm assuming you knocked a vacuum line lose
Old Sep 8, 2011 | 08:23 PM
sayala37's Avatar
sayala37
I will keep looking??? Gotta be though right!
Old Sep 10, 2011 | 04:50 PM
sayala37's Avatar
sayala37
okay so i've looked and can't see any line that came loose or cracked? So frustrating because the truck was fine in the morning! All I did was repalce the pulley?? Could it be a fuse? I thought it was the line coming off the air intake, because I was trying to move it out of the way to get the drive belt on? If the belt is not centered correctly would that have an effect on anything? doesn't seem to be out of position but there was a spacer that came with the pulley and it said to use if needed but the belt lines up fine? Just trying to think out of the box.
Old Sep 10, 2011 | 05:50 PM
alloro's Avatar
alloro
I know it's a dumb question, but are you sure the belt is routed correctly?
Old Sep 12, 2011 | 07:16 PM
eriklynden's Avatar
eriklynden
Maybe u knocked a spark plug /coil connection out and the spark is jumping safe bet to check maybe reset the computer with battery disconnect Although I bet you did that with your code reader. Let us know what it was I replaced my air filter and cleaned my trottlebody did plug etc. and for some weird reason I had that issue aswel
Old Sep 12, 2011 | 08:30 PM
jk080's Avatar
jk080
Transmission Rebuilder
Check Fuse #23
Old Sep 13, 2011 | 03:27 PM
Gage2502's Avatar
Gage2502
I never heard of a A/C bypass pulley, where did you get that from?
Old Sep 13, 2011 | 09:16 PM
LeeLeadingham
I've found it available at Advance Auto Parts, Autozone, or RockAuto.com
Zacbkennedy
Jun 22, 2017 07:18 PM
eightball8
May 10, 2013 09:09 PM
Frankenbiker
Jun 27, 2012 11:54 PM
tajon
Jul 16, 2010 09:05 AM
73FOMO
Jan 1, 2007 01:16 AM
