MPG?
Old Sep 9, 2011 | 08:30 PM
william_04_x's Avatar
william_04_x
Originally Posted by 69cj
All these ambiguous mileage statements. I was getting 18 or 20 mpg. Is that hiway, city, towing, falling off a cliff or what? I can say I'm getting a certain mpg. If I don't state the circumstances and speeds it means squat. Just trying to compare apples to apples and not apples to rocks going over a cliff. Sorry for the rant but not one of the mileage claims as stated meant squat.
208 miles/131 minutes/18.5 MPG. A friend of mine did that on the highway recently.
It also seems that long term high rpm operation can accelerate the degradation of a questionable FICM.
Old Sep 9, 2011 | 08:34 PM
Bob2626's Avatar
Bob2626
For real, Just completed a 3k trip from WA to NH pulling a 30ft. 5th, bone stock with repair in Billings MT for a blown inter cooler, got 9 mpg average for the whole trip.
If the turbo boost gets any where near the red line it might be time to check or change the inter cooler, might be getting plugged up. Does anyone know where the boost is measured?
Bob
forgot to say it is a F250 2005 year.
Old Sep 9, 2011 | 09:13 PM
william_04_x
Bob
Boost is measured by the MAP sensor on the intake manifold. A plugged IC would not create/show high boost numbers. MAP sensor is located on a bracket at the rear of the passenger side engine bay. You can check to see if the hose from the sensor to the intake manifold is loose, or clogged.
Old Sep 9, 2011 | 11:10 PM
zhilton's Avatar
zhilton
Originally Posted by cheezit
I would do no such thing
Yeah right.
Fair is fair...I drive an early '04 F250 3.37LS 5R110 equipped truck. On the highway (interstate) I keep the speed at 70mph or slightly below. I roll off the stop signs/lights and roll up to them; I don't jab the brakes or pin the go pedal (except every couple of weeks for that "tune-up"). I'm running Michlin's pumped up to 60 psi; oil changes every 5k (Mystic synthetic blend 15W40) and fuel filters every 10k; OEM filters. The only thing about my truck that isn't stock is the ZooDad & no-cat. These are my numbers for the last 18 months (103 fill-ups/44k plus miles); most of those miles are empty...but there are several tanks logged with a trailer or load in the bed.
Pavement Princess (Ford F-250 Super Duty) | Fuelly
These trucks will never get Focus mileage, but with some discipline they will get better than 10 mpg. Unless fuel is so cheap where you live that you can afford to blow it out the tailpipe.
Old Sep 10, 2011 | 03:15 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
lifted on 35" tires, 90% city driving. 12.6 to 13 mpg by Lie-Meter...13.6 mpg calculated by hand. Most likely is actually almost 14 mpg though because my speedo isn't calibrated for the 35" tires
I drive fairly easy most of the time. grandpa it from lights and other stops...nice long slow-downs. Lots of traffic makes me be very careful when driving.
do try and open her up occasionally though every outing.
I've noticed that she doesn't like highway RPM's. I get better city MPG than highway MPG. Really need to get some gauges so I know what is going on.
Old Sep 10, 2011 | 07:13 AM
Bob2626's Avatar
Bob2626
thanks for the info Will, if the map sensor is where the turbo value is taken it could not have been a bad inter cooler.
Sounds like some are getting very good millage, I havent had the truck long enough to get any average not towing.
Bob
Old Sep 10, 2011 | 10:59 AM
96_F250_Deezal's Avatar
96_F250_Deezal
I do a simple calculation; gallons used divided by miles driven
on average I fill up with 26 gallons and typically go 525 miles on a tank, this equates to 20.19 MPG.
it may not be completely accurate, but it gives me an idea about that the truck is doing.
Old Sep 11, 2011 | 04:18 PM
User 71024's Avatar
User 71024
Originally Posted by trober_603
is it a twin turbo 6.0 or single? what gears? 6 Speed or Auto? 4wd or 2wd? my uncle had a 06 one ton 4wd 6.0 with twin turbos and it come out with 4.11s and got like 14 or 15 on the hwy and 8 in town
IT's a single rear with 3:73, and single turbo with auto, completely stock. And thanks for the intelligent response.
Old Dec 1, 2011 | 04:18 PM
groy's Avatar
groy
I've always divided the miles driven by gallons....gallons by miles would really kill the MPG...
Old Dec 1, 2011 | 07:55 PM
Unrealo4's Avatar
Unrealo4
Man I don't know what you guys are doing wrong. I get 17.5 mixed driving every tank. The only thing that changes that is winter fuel drops it to 15.5_16ish.
zeroo
Jun 16, 2018 09:28 AM
bigblue56
2009 - 2014 F150
Sep 14, 2017 06:24 AM
pattycake678
May 23, 2010 11:51 AM
mattebury
6.4L Power Stroke Diesel
543
Nov 13, 2007 05:06 PM
Stevie Ray
Nov 22, 2006 05:35 PM
