Idle throttle only
Old Sep 7, 2011 | 08:08 PM
hammer65's Avatar
hammer65
Idle throttle only
Hey Guys: I pulled into Gutherburg, Nebraska KOA. Everything fine except radio had quit. Checking fuses and got radio to working, and have lost all throttle except Idle. I have a code, but I left it at the trailer. It indicated throttle sensor or something. I have a 2003 7.3 , stock except for an old edge program. I know that I have seen this on here before and am searching more as soon as I post this. Please help. Jim
Po221 code
Old Sep 7, 2011 | 08:43 PM
tritonman2001's Avatar
tritonman2001
Throttle position sensor down at the pedal is probably bad. I cant remember if you can get just the sensor, or if you hve to get the whole assembly.
Old Sep 7, 2011 | 10:40 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Po221 code
Is your instrument cluster working? If not, it could be the OD wire shorted out...that would be a less expensive item to fix. Have you checked your fuses?
Old Sep 8, 2011 | 01:19 AM
SpringerPop's Avatar
SpringerPop
If I were a betting man, I'd bet that Greg is right ON with this one!
Pop
Old Sep 8, 2011 | 08:24 AM
hammer65's Avatar
hammer65
Fuses all check good. No dash lights at all. No gauges either. Internal OD wires were broken a couple of years ago, and soldered back together.
Greg may be on to something. Thanks Jim
Old Sep 8, 2011 | 08:30 AM
hammer65's Avatar
hammer65
Can I just unplug it?
Old Sep 8, 2011 | 09:54 AM
SpringerPop
Yes you can, but you WILL have a blown fuse, and you gotta' replace that.
Pop
Old Sep 9, 2011 | 07:13 AM
hammer65's Avatar
hammer65
Well Pop you hit it. In my tired hast, old age, half blind, stupidity, I pulled a fuse while trying to fix the radio. Put it back in the wrong whole. This just happened to be the fuse on the bottom row, around # 40,41, or something.
Jason, a really nice guy at Pony Express Chevrolet in Gothenburg, Ne. found it for me and at a very fair charge. A really super nice young man. He called a Ford Dealer and talked to someone and then started checking. Thanks Guy's for all your help. I really appreciate it. Jim
Old Sep 9, 2011 | 09:22 AM
SpringerPop
Glad you're back on the road!
You won't have overdrive lock-out, and the light won't flash if you are having a trans problem, but you CAN move!
When you fix this problem, you probably should consider just replacing the entire shifter lever with all the internal wiring, etc. It's not that crazy-expensive to just do the whole thing.
Pop
Old Sep 9, 2011 | 10:37 AM
Shake-N-Bake
Pop
I think what Jim is saying is that he pulled the fuse for the OD-TPS-Instrument circuit and put it back in the wrong socket. He might not have actually blown a fuse...just didn't put it back in the correct spot. (at least that is what I got out of his post....)
Old Sep 9, 2011 | 06:08 PM
hammer65's Avatar
hammer65
Greg is correct. I am sorry for not making myself clearer. I pulled the fuse for the dash instruments,and the TPC and put it back in the wrong hole. I checked every fuse in the panel, and not once did it occur to me, what I had done.
But some of you may understand how hard it is to look up at something under the dash with Bifocals. But I want to again thank you guys for all your help. Jim
Old Sep 9, 2011 | 07:49 PM
SpringerPop
i share your type of optics, only three focal lengths, and yea, it's more difficult than when I was a youngster...
Pop
tomsykes004
Jun 18, 2019 07:54 PM
kstones63
13
Jun 5, 2014 08:04 PM
gijoe985
1997 - 2003 F150
Jul 15, 2008 11:03 AM
gdoggy
1983 - 2012 Ranger & B-Series
Jun 19, 2003 09:48 PM
brown 4x4
Sep 4, 2001 02:08 PM
