throttle position sensor
Old Sep 3, 2001 | 10:28 AM
brown 4x4's Avatar
brown 4x4
I checked the codes on my truck the other day and came up with code 23 "Throttle sensor out of range or throttle set too high." First of all, does this mean my TPS is bad? Where would it be located? I have the electronic feedback carb. Second, could this be why it won't idle till it "warms up" a little? Thanks for any advise.
1986 F-150 4x4 300 I6 NP435
Old Sep 4, 2001 | 08:12 AM
chip58's Avatar
chip58
The tps is at the base of your carb. It's actuated by the the same rod that operates the throttle butterfly. I believe it has a four wire connector. You can remove it for cleaning with electronic parts cleaner, though it's not adjustable.
Yes, it could affect your idle.
Old Sep 4, 2001 | 02:08 PM
78moneypit's Avatar
78moneypit
Dec 28, 2016 05:17 PM
2001NaviA4WD
Jun 28, 2016 07:56 AM
75Three90
Mar 12, 2016 05:37 PM
LSAtexan4x4
Oct 12, 2011 09:16 PM
magnet1
2004 - 2008 F150
Dec 17, 2010 02:29 AM
