Sponsored by: Real Truck
heater problems
Old Sep 7, 2011 | 07:32 PM
Lownslowsrt's Avatar
Lownslowsrt
heater problems
i have a 04 F250 lariat fx4, we have had some cold weather in the early AM, and i have found out my heater doesnt get warm/hot at all, and also my heated seats aren't working.... anyone have opinions?
Old Sep 8, 2011 | 12:38 AM
Kid Geoff's Avatar
Kid Geoff
Are you driving enough in the am to actually warm up your car?? If so, either you are low on coolant or somebody bypassed your heater.
The heated seats is another matter. Those are electric. Check fuses. If they were an add on...make sure they're wired in...
Old Sep 8, 2011 | 01:21 PM
Lownslowsrt
Yea truck gets to running temp about a 1/4 way to work, the seats are the power with heated and the power seat part works jus not the heater part
Old Sep 8, 2011 | 04:10 PM
clem1226's Avatar
clem1226
need to make sure you have coolant flow through the heater core, that's pretty much it for the heater...... unless the blend door is stuck in vent, can you get heat on defrost?
the heated seats.....are both seats inop?
Old Sep 8, 2011 | 05:30 PM
Lownslowsrt
yea both seats are inop, and i will go try heat on defrost right now to see
Old Sep 8, 2011 | 05:37 PM
Lownslowsrt
ok i had jus got home from work, truck is at full running temp switched it to defrost and let it run... still blowing cold, so how do i see if the heater core is getting the fluid?
Old Sep 8, 2011 | 06:54 PM
bpounds's Avatar
bpounds
What engine do you have? If it is the 6.0 diesel, this could be bad.
Old Sep 8, 2011 | 07:05 PM
Lownslowsrt
It is a 6.0, I have no CEL's
Old Sep 8, 2011 | 07:23 PM
bunklash's Avatar
bunklash
For sure check your coolant level. Check it at the "degas" bottle, also known as the coolant reservoir. Let us know.
Old Sep 8, 2011 | 07:27 PM
Lownslowsrt
Alright I will when I get home
Old Sep 8, 2011 | 07:30 PM
dchamberlain's Avatar
dchamberlain
Check the temperature of the heater hoses. They should be about as hot as the radiator hoses.
Old Sep 8, 2011 | 08:09 PM
bpounds's Avatar
bpounds
Yes, take a good look at the coolant degas bottle, as bunklash noted. The 6.0 has a bad habit of losing coolant, which can be due to a failed EGR cooler, oil cooler, or head gaskets. Folks who don't check their coolant frequently will sometimes notice the lack of heater function as their first symptom.
Beyond that, the usual things that can affect the heater also apply, such as the heater control valve being disconnected from the vacuum supply, plugged heater core, bad water pump, etc.
But unfortunately, more often than not, it is an engine problem. Sorry to say.
Old Sep 8, 2011 | 08:11 PM
Lownslowsrt
Well knock on wood truck runs great havent noticed any leaks temps stay normal even when its 100+ degrees
Old Sep 8, 2011 | 08:14 PM
bpounds's Avatar
bpounds
That means nothing. No CEL means nothing too.
This thread would best be moved to the 6.0 forum aye sap.
Old Sep 8, 2011 | 08:35 PM
Lownslowsrt
When I get to my desktop I will post in there
CPT_Diesel
Dec 10, 2007 10:49 AM
Mikes92F250
Nov 8, 2007 10:32 AM
rondocycle
6.4L Power Stroke Diesel
Jun 19, 2007 11:00 AM
flfisher2002
Oct 3, 2006 09:35 AM
