Steering Coupler
Old Sep 25, 2011 | 02:38 PM
tmcalavy's Avatar
tmcalavy
Are the shoes good? If so, spray a butload of PB Blaster or Kroil inside the back of the brake hub (bottom) and let the star adjusters soak...then use a brake tool and adjust the shoes out as you spin each wheel (jack)...you want the shoes dragging a little, then back them in slightly. If that doesn't help your pedal, you need to ditch the old brake fluid, refill the master and bleed the brakes...lube the bleed fittings at each wheel, too. If you need new shoes, have fun...drum brakes are a gas.
Old Sep 26, 2011 | 08:57 PM
WmBaldwin57's Avatar
WmBaldwin57
Ok I thought I would change the oil this weekend on this 69 and I think I remember an old Ford commercial that said "Ford has a better idea?". I guess that person never saw the location of the oil pan drain plug, WTF? Who engineered this piece of work, the middle of the cross member, really.
Old Sep 27, 2011 | 09:20 AM
tmcalavy's Avatar
tmcalavy
Yeah, they could have engineered that better. On my 360, you have to get to it from the front of the engine...that gives you enough room to get a wrench on the plug and get some leverage...but then the oil still drains all over the place, use a wide catch pan and lots of rags.
Old Sep 27, 2011 | 10:20 AM
elgemcdlf's Avatar
elgemcdlf
We used to laugh whenever we seen one of "Ford's Better Ideas". Anything like you speak of went in that group. A piece of cardboard creating a ramp into the pan should help a bit.
mrpotatohead
Dec 2, 2016 10:10 AM
78150custom
Sep 9, 2009 12:04 PM
65fordguy
Nov 4, 2007 09:33 AM
Angry Slide
Dec 5, 2006 10:15 AM
frigerator
Jun 19, 2004 01:17 PM
