No Horn
Old Jun 17, 2004 | 11:51 PM
frigerator's Avatar
frigerator
No Horn
On a 1975 crew cab f250 I can't seem to get the horn to work. I pulled the steering wheel and I can get it to honk by pushing in the spring laoded button and touching the outer column at the same time, but it won't work when I touch the steering shaft and spring at the same time.
Old Jun 18, 2004 | 07:34 AM
76supercab2's Avatar
76supercab2
Is this a 2wd? If so then there should be a wire on the rag joint next to the steering box. This wire connects the shaft in the steering column to the steering box, grounding the steering shaft in the column. The wire goes from the nut on the steering shaft side across to the nut on the steering box side.
Old Jun 19, 2004 | 01:45 AM
frigerator's Avatar
frigerator
It is a 2wd. Are you talking down by the frame of the truck? What color of wire? There is two wires that have been cut behinde the steering wheel on the right. There are six wires on a block. The two closest to the shaft are gone. Don't know what color or what they are for.
Old Jun 19, 2004 | 08:22 AM
76supercab2
Under the hood. Look at the joint between the steering column and the steering box. I think the wire is green but it doesn't matter. The wire is NOT part of a harness. It just goes from a bolt on one side of the steering coupler to a bolt on the other side. If there is no wire on the steering coupler this is you problem.
When you touch the wire to the steering shaft there is no ground because the steering coupler insulates the steering shaft from the chassis (ground plane) of the vehicle. The outer column is grounded to the chassis by its mounting bracets. The horn works by grounding the circuit. The steering box is grounded because it is mounted to the frame. Wire the steering column to the steering box at the steering coupler.
Old Jun 19, 2004 | 01:17 PM
frigerator's Avatar
frigerator
Thank You ! I'll go to my Uncles and take a look. He's got to trucks that the horns don't work.
GormGorm
Apr 4, 2010 11:21 PM
chaser1602
Oct 1, 2009 09:58 PM
sleddog60
May 18, 2009 09:29 PM
daggerNC
18
Nov 7, 2004 07:28 PM
yorxs
Aug 14, 2003 12:56 PM
