No high beams
Old Sep 6, 2011 | 06:22 AM
76gdmn's Avatar
76gdmn
No high beams
I added a hitch and 7 pin trailer plug recently, and just noticed that i no longer have high beams. The low beams work fine, but when kicking on the brights the headlights just shut off. After doing a search it seems the dimmer switch goes out all the time, but would it just be a coincidence that it went out at the exact time I did some other wiring?
Or could I have done something else to cause it to have no brights?
Old Sep 6, 2011 | 06:46 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Can't see how it could be related. Sounds like dimmer switch. They were probably out before and you just hadn't noticed.
Old Sep 6, 2011 | 07:27 AM
jim collins's Avatar
jim collins
Sounds like dimmer switch and yes coincidences can happen. I just recently had an old tape player in one of my old cars jam up and kept on trying to eject killing the battery over night i thought. Ended up the battery had just lived it's life time and went dead. It was just a coincidence they both happened at the same time. It was good it happened in my drive way than out in the middle of no where .
Old Sep 6, 2011 | 08:21 AM
toymobile's Avatar
toymobile
lights
Unless you cut the wire feeding HB just happens that way, good luck
Old Sep 6, 2011 | 08:24 AM
toymobile's Avatar
toymobile
lights
check dimmer switch
94windsor
Oct 1, 2019 12:23 PM
Monteg0
Jan 26, 2014 04:35 PM
70_F250_390
Feb 18, 2011 10:15 AM
petelynch
Jun 15, 2007 12:57 PM
jeff5683
Jun 17, 2006 08:07 AM
