High beam flickering
Old Feb 15, 2011 | 10:59 PM
70_F250_390's Avatar
70_F250_390
When driving my 71 f250 highboy home tonight, my headlights started flickering on and off. It only happened when I had the high beams on for a couple of seconds and it didn't flicker with just regular headlights. Anyone know what's up?
Old Feb 16, 2011 | 05:18 AM
Talltruck's Avatar
Talltruck
Usually it's the dimmer switch going bad. If they work good on low beam about all you change in the circuit when you go to high beam is from the dimmer switch to the headlight, and the dimmer is what toggles it back & forth.
Old Feb 16, 2011 | 08:51 AM
Garrett-25's Avatar
Garrett-25
Try your dimmer switch, sometimes the connector comes loose, same thing happened on my 72, I just unpluged it blew it out and put it back in and haven't had a problem sence. I know why it just flickered on the high and not the low.
Old Feb 16, 2011 | 05:57 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
If changing the dimmer switch doesn't fix it, changing the headlamp switch might.
The headlamp circut breaker is inside the headlamps switch itself. When they get old the resistance increases and the circut breaker triggers. (Usually happens on both Hi and low beam though)
Another cause for this problem with the headlamp switch circut breaker triggering is caused by upgrading the headlamps to halogens or brighter. So if you just upgraded the headlamps then you may need to upgrade the wiring and add relays.
Whiter Whites, Brighter Brights .: Articles
Old Feb 16, 2011 | 06:32 PM
sandmanf250's Avatar
sandmanf250
i recommend pulling socket on back of the bulb first and look for corrosion first.if none follow other posts.good luck
Old Feb 18, 2011 | 10:15 AM
69monster's Avatar
69monster
I'd say dimmer switch for hight beams, and if your low beams quit it's the headlight switch its self.
AKHunter93
Aug 3, 2015 05:57 PM
79ranger150
Mar 18, 2015 09:11 PM
1968 F100 Ranger
21
Jan 25, 2015 03:53 PM
acf6
Jun 21, 2014 12:30 AM
300sixnick
30
Jan 21, 2014 11:06 AM
