Headlights not working
Old Jun 15, 2007 | 08:48 AM
petelynch's Avatar
petelynch
I originally had no headlights, so I replaced the dimmer switch, now i press the switch the lights come on, I press it again and they turn off. I cannot figure out why I can't get both hi's and lo's to work?????
Old Jun 15, 2007 | 09:51 AM
MikeWire's Avatar
MikeWire
This might be a little obvious, but maybe the low beams have burnt out so all you are seeing is the high beams turning on/off? Maybe replace both lamps and see what happens?
Old Jun 15, 2007 | 10:07 AM
petelynch's Avatar
petelynch
I ran hard wires off the battery to test the lamps and both hi's and lo's checked out fine. I also ran the ground straight to the battery to check for proper grounding and nothing???
Old Jun 15, 2007 | 12:57 PM
Mil1ion's Avatar
Mil1ion
Try another dimmer switch.
mustangpt
Apr 22, 2015 09:59 PM
VanHaulen
Electrical Systems/Wiring
Mar 24, 2013 03:42 PM
1986fordrangerman
1997 - 2003 F150
Feb 5, 2009 09:42 PM
MintFord
Dec 23, 2006 07:57 PM
jayfab2000
May 23, 2005 05:04 PM
