Strange headlight issue...
Old Jan 26, 2014 | 01:06 PM
Monteg0's Avatar
Monteg0
Anyone else had this happen?
Yesterday morning I got up early to go to work and when I turned on my headlights, neither headlight lit up. I quickly surmised my headlight switch had gone bad, since at some point I've had to replace one in every ford of this vintage I've owned. After work, I picked one up at Napa, swapped it in, but still had no headlights.
At this point I grabbed my test light, and started testing wiring. While I was doing that I accidentally stepped on the high beam switch and the high beams came on! I hit it again, and I had low beams... So I shut them off and back on. No lights until I hit the high/ low switch again. I bought a new high low switch but haven't put it in yet. I guess maybe it's shorting out? I've never had this happen before but it makes sense that the circuit runs through that switch.
Old Jan 26, 2014 | 01:47 PM
White 97 xlt's Avatar
White 97 xlt
Very common with the floor mounted dimmer switches.. While replacing it be sure to check the dimmer switch plug , it may be toast also..
Old Jan 26, 2014 | 04:35 PM
Monteg0's Avatar
Monteg0
Huh. I've had 4 fail over the years, they either didn't do anything or wouldn't push at all.
I'll definitely give the plug and harness a good check over, thanks for the tip!
Twilight Fenrir
16
Sep 22, 2012 01:13 PM
70_F250_390
Feb 18, 2011 10:15 AM
grams72
Sep 23, 2009 08:48 PM
eman resu
Electrical Systems/Wiring
Feb 20, 2007 08:56 PM
GregTruck
Dec 7, 2004 08:20 PM
