Window regulator help
Old Sep 5, 2011 | 06:44 PM
afdaf's Avatar
afdaf
The driver's side window on my 78 F-150 will no longer crank up or down. I pulled the door panel off and can see that the teeth on the crank are no longer engaging the teeth on the regulator. I don't believe the teeth are stripped because the everything was working fine a day ago. Is there anyway to adjust the teeth so they mesh or am I better off just getting another regulator? Thanks in advance
Old Sep 5, 2011 | 07:14 PM
Ciin's Avatar
Ciin
Prob should remove it, asses the problem but it will most likely need replacing but ya never know.
Old Sep 5, 2011 | 08:29 PM
Normmus's Avatar
Normmus
I just went through this today, I replaced it and fixed the problem, but needed to remove the regulator to assess the problem first. I did not notice any kind of adjustment, it seems to be a part that you throw away and replace.
Old Sep 5, 2011 | 09:27 PM
jmikeyj4's Avatar
jmikeyj4
how do you even take the regulator out it looks like a pain in the ***
Old Sep 5, 2011 | 10:07 PM
Ciin's Avatar
Ciin
drill it out and get some new fasteners
Old Sep 6, 2011 | 01:01 AM
starwriter's Avatar
starwriter
I didn't need to drill mine out, I think it was just 3 bolts and then sliding it off of the track that is connected to the window. I originally replaced it with an aftermarket but that was junk and couldn't even hold the window up. I found a NOS on ebay and it has worked well ever since.
Old Sep 6, 2011 | 01:09 AM
Ciin's Avatar
Ciin
Nice! Mine were aluminum rivets.
Cerpindicular
Jan 9, 2011 08:12 PM
crum71
15
Jun 20, 2008 07:23 PM
87liftRanger
1983 - 2012 Ranger & B-Series
Dec 24, 2003 07:05 PM
YWAMNick82f150
Nov 25, 2002 10:46 PM
PetesPonies
Jun 23, 2000 09:12 PM
