Well it happened
Old Sep 5, 2011 | 02:54 PM
AGE mechanic's Avatar
AGE mechanic
Well it happened
Well, the truck has been fine since the the Head Gaskets and BPD. I was headed back to Phoenix down the 87. I was climbing the hill to the top of Mt. Ord. Near the top, big explosion under the hood. I knew what it was right away. A clamp on the Turbo broke. No power. I limped to the pull off area. called AAA for the ride home. He pulled up in a big Ford flatbed. I asked him if he has had many problems with his. He had 290K miles on it and he said he has had no issues at all. I was in disbelief, then he said it had a Cummins in it.
Old Sep 5, 2011 | 04:43 PM
Unrealo4's Avatar
Unrealo4
There's a reason its in a ford body!
Old Sep 5, 2011 | 05:00 PM
bismic's Avatar
bismic
Spare clamps are cheap - good to have one in an on-board toolbox.
That particular failure is no big deal unless you are over boosting w/ a possible turbo problem.
Lots of people have reached 200k+ miles on a 6.0L without any significant issue. However, seems like injector life is in the 200k to 250k mile range - when treated to good fuel pressure and clean oil!
Old Sep 5, 2011 | 05:48 PM
Maxium4x4's Avatar
Maxium4x4
For a 2006 I bet you had an overboost unless the clamp was not installed right.
Old Sep 5, 2011 | 06:46 PM
69cj's Avatar
69cj
You can get a dryer exhaust clamp for next to nothing at AZ. It's not a fix but will get you off the hiway in one piece.
Old Sep 5, 2011 | 07:18 PM
Unrealo4's Avatar
Unrealo4
Did you replace the clamp during your head job? You could have over torqed the clamp and it broke after being heated up and expanding. I don't see this as a ford problem. But go on complaining and i'm sure someone will give you some cheese for your whine!
Old Sep 5, 2011 | 07:27 PM
Dunatic's Avatar
Dunatic
Hahaha.... Lmao!
Old Sep 5, 2011 | 07:36 PM
AGE mechanic
Probably over torqued.
Old Sep 6, 2011 | 11:19 AM
bpounds's Avatar
bpounds
x2. I bought a couple and keep them in the toolbox.
The nice thing is, once you buy a spare clamp, you are guaranteed to never need one. Or so it seems.
fastone
Dec 15, 2010 06:38 PM
HCJtruck
Aug 1, 2010 06:19 PM
paul100
Jul 24, 2007 07:08 PM
NJTy180
Jan 3, 2007 08:43 PM
Flux
Aug 7, 2006 08:28 PM
