2000 Excursion sometimes will not go into park, rolls
Old Sep 5, 2011 | 01:00 PM
proudfrog's Avatar
proudfrog
My excursion sometimes doesnt go into park all the way. On occasion, I have to start it in neutral. My wife has noticed a few instances where it will start to roll. When that happens, we cycle the shift from P to N and then back again and it seems to hold the P position and then it will start.
Any suggestions on a fix or cause?
Old Sep 5, 2011 | 04:47 PM
Lollygagger's Avatar
Lollygagger
I had something similar where the shifter would not go completely into park and the engine would not turnover until I put it into neutral. The solution was a five minute fix at the local garage to adjust the linkage under the dash.
Hope this helps.
Old Sep 5, 2011 | 04:55 PM
proudfrog's Avatar
proudfrog
thanks. It gives me a place for me or my mechanic to start.
Old Sep 5, 2011 | 05:13 PM
labman1014's Avatar
labman1014
Could also be just the screws that hold the shift lever to the linkage. To see what I'm talking about, I will have to take the knee panel off and lay on ur back looking up at the column. Wiggle the shifter and u will see where it meets the linkage. Usually the 2 screws loosen over time. Some even fall out. I would start there b4 u start throwing money at it.
Old Sep 5, 2011 | 05:14 PM
RACERX7775's Avatar
RACERX7775
search a bit on shifter cable and such related topics. there are a couple of tiny torx bolts that hold the linkage under the column. these bolts fall out or come loose or both. this will cause the shifter to move and not the cable to move at the trans. pull the panel off the dash, stand on your head and follow the cable assembly down and its right under the steering shaft. you should see two or three, like t20 or t25 torx bolts. most likely they fell out.
Old Sep 5, 2011 | 05:20 PM
2FordTrucks's Avatar
2FordTrucks
Mine did the same thing. I tried the torx screws in the back and that did not fix it. The adjustment was made at the transmission.
Old Sep 5, 2011 | 07:17 PM
RACERX7775's Avatar
RACERX7775
labman, were we thinking and typing the same thing at the same time or what??????
Lost_in_tx
Dec 21, 2016 09:30 AM
dtmfman
Jun 11, 2013 08:30 PM
jamesbaughman333
Oct 1, 2012 12:33 PM
denvertruckman
Apr 26, 2009 08:20 AM
smccatv
Jun 23, 2008 06:13 PM
