Sponsored by: Real Truck
sub boxes
Old Sep 5, 2011 | 10:31 AM
5.4mcnaughton's Avatar
5.4mcnaughton
sub boxes
does any body know where i can get a sub box that would fit in my 99 f250 super cab? ive looked everywhere and nobody has anything that fits under or behind the rear seat.
Old Sep 5, 2011 | 10:50 AM
Pili's Avatar
Pili
The MTX ThunderForm will fit under the seat. I don't think anyone makes a sub enclosure for behind the seat in a super cab.
Old Sep 5, 2011 | 11:42 AM
Big Goof's Avatar
Big Goof
I made a sub box to fit behind the seat of a 99 supercab. I'm just working on how to relocate the seat forward.
Old Sep 5, 2011 | 11:45 AM
5.4mcnaughton
what size subs would it fit, is it possible to move the seat forward with out fabrication?
Old Sep 5, 2011 | 12:19 PM
Big Goof's Avatar
Big Goof
My box is built for 2 MB Quart shallow 12's. The seat latches to the back of the cab, so you cant get anything back there without relocating it.
I was going to make a set of seat risers to bring the seat up and out a few inches. The only other option that I can see working in a supercab, is a JL stealth box that fits in the console.
I'm still workin on my setup, but will post pics if I ever get it done.
Old Sep 5, 2011 | 02:14 PM
5.4mcnaughton
seat risers would be an easy install except for you would have to relocate the rear seat brackets, should be interesting if you make it work plese send pics
Old Sep 5, 2011 | 03:47 PM
davidjurss's Avatar
davidjurss
The MTX Thunderform will fit perfectly under the seat. I have one in my 2000 Super Cab. I get a good sound out of it, and the box color matches the interior pretty good.
Ive never seen anyone put subs behind the seat, only amps. I think it would be interesting to see, but there already isnt a lot of room to begin with back there.
Old Sep 5, 2011 | 03:49 PM
2000silverbullet's Avatar
2000silverbullet
I used a Q-logic rear center console with a JL 10" sub in my 2000 SC, worked great and very durable.
Old Sep 5, 2011 | 05:56 PM
Big Goof's Avatar
Big Goof
The rear seat is different in the '99. It folds flat and there is basically no room under it.
Old Sep 5, 2011 | 06:30 PM
davidjurss's Avatar
davidjurss
Isnt there 2 different designs in the 99 though? I seem to recall there being a difference between early 99 and late 99 with a lot of different parts.
Old Sep 8, 2011 | 02:20 PM
yesitisrob's Avatar
yesitisrob
I have the captains chairs in my backseat. I was able to fit 2 mephis PR12's and my amp back there no problem. Its tight but it fits fine. Did have to remove the carpet from the back wall to give me enough room and take out the roadside kit (jack, etc). Since you have a bench seat I have seen some boxes that are meant for "shallow mount" subs, but they dont hit nearly hard enough for me.
Old Sep 8, 2011 | 02:50 PM
Fosters's Avatar
Fosters
If you have a 40/20/40 seat in the front, JL audio makes a stealthbox that replaces the "cushion" in the jumpseat. If you have the full size console and buckets, they also make a stealthbox that goes in the console, still leaves a bit of room and raises up the console a bit.
They are pricey, but well worth it IMO.
Old Sep 8, 2011 | 08:32 PM
Arlene's Avatar
Arlene
Just passing through...
I have the one that replaces the jumpseat cushion. Love it!
PlatinumPete
13
Jan 11, 2010 02:31 PM
dynamis5
2004 - 2008 F150
15
Jul 20, 2007 11:33 PM
blueeyes2478
13
Jun 3, 2006 05:31 PM
f-150_38.5s
28
Mar 26, 2006 03:38 PM
123svt
1983 - 2012 Ranger & B-Series
Apr 13, 2003 12:29 AM
