REPLACING 6.0 ENGINE
Old Sep 5, 2011 | 12:14 AM
WOLVERINECYCLE's Avatar
WOLVERINECYCLE
Question REPLACING 6.0 ENGINE
I HAVE 2 6.0 TRUCKS, ONE OF WHICH HAS CRACKED HEADS AND IS LEAKING DIESEL INTO THE COOLANT. SINCE IT IS A 2003 WITH 350,000 MILES; I WANT TO JUST REPLACE THE ENGINE COMPLETELY...ANY ADVICE WOULD BE APPRECIATED.
Old Sep 5, 2011 | 04:27 AM
bismic's Avatar
bismic
Is everything else in such good shape that you really want to replace the engine? It may be a better deal to find a lower mileage truck. I have seen some 2006 6.0's going for 25k or so. Also I have seen some 2003's w/ 150k go for 12k or so, which is at least what a new engine will cost you.
What shape are the injectors in, .... and the turbo?
Old Sep 5, 2011 | 09:07 AM
cheezit's Avatar
cheezit
engine comes out the front. not a bad job.
Old Sep 5, 2011 | 09:15 AM
WOLVERINECYCLE
THE TURBO AND INJECTORS HAVE WELL OVER 100K SINCE REPLACING THEM. MY DIESEL SHOP SAYS THEY CAN PUT IN A LOW MILEAGE(50K) ENGINE FOR $6,500 TOTAL COST WITH A WARRANTY. I APPRECIATE ANY THOUGHTS ON THE SUBJECT, AS I WANT TO MAKE THE RIGHT MOVE.
MATT
Old Sep 5, 2011 | 09:17 AM
cheezit's Avatar
cheezit
if the engine is good and I liked the truck I would do it all day long
Old Sep 5, 2011 | 09:58 AM
WOLVERINECYCLE
THANKS FOR THE QUICK REPLY. BEING THAT IT IS A 2003, DO I HAVE TO MATCH UP THE YEARS, OR CAN I GET ANY 6.0?
Old Sep 5, 2011 | 10:44 AM
Krump's brother's Avatar
Krump's brother
I know my opinion doesn't carry the weight that cheezit's does, but that's a pretty screaming deal.
Is there anything (experts?) that should be done to the engine before it goes in-stuff that's way easier on a stand versus in the truck?
Old Sep 5, 2011 | 10:59 AM
Piolet's Avatar
Piolet
I don't know where you're located, but if you have salt on the roads in the winter, while the engine is out take the oil pan off and have it kevlar coated .
$800 to replace it on an installed engine and mine looks like crap ... I can almost put my finger through it.
Cheaper if you do it yourself but it looks like a right pain for anyone but a seasoned wrencher.
Old Sep 5, 2011 | 12:09 PM
Hank85713's Avatar
Hank85713
maybe have them do the oil cooler etc while its out. have all the current tSB installed that way you will have an up to date engine or as close to it as possible. Just a thought.
Norma stitz
Oct 1, 2016 09:52 AM
vectrex
Jun 4, 2013 10:02 PM
letsroll93
Oct 15, 2008 05:56 PM
redmt77
May 30, 2008 09:37 PM
Todder
Oct 7, 2004 06:57 PM
