Can you identify this axle?
Sep 4, 2011 | 02:16 PM
Truck is a 97 F250 Heavy Duty 4X4. The door tag says C5 axle which the owners manual says is a 4.10 ratio, but doesn't identify the actual axle. Can you tell me more about this axle? What type? Limited slip? etc etc......
Sep 4, 2011 | 02:21 PM
Sep 4, 2011 | 05:07 PM
That's a Sterling with 4:10 gears non limited slip.
Sep 4, 2011 | 06:53 PM
That IS a limited slip with 4.10 gears.
Sep 4, 2011 | 07:09 PM
Quote:
Originally Posted by
White 97 xlt
the L denotes a Limited slip.....Just a tidbit......
if it had've read 410...then it woulda been a Non Limited slip...
4L10 means a Limited Slip...
Sep 4, 2011 | 07:24 PM
AWSHUX
You're right, guess I need to learn how to read!!
Thanks for the correction....
From the chart:
C5 4.10. 6250 FORD LIMITED SLIP
Sep 4, 2011 | 07:46 PM
White 97 xlt
From the chart:
It's fine....just a mental note for the future....
Sep 4, 2011 | 10:05 PM
Not sure how obvious it may be to you, but just to clarify, its a Sterling
10 1/4, not the later 10 1/2.
Sep 4, 2011 | 11:02 PM
Wow thanks to everyone for all the info!
grumpyinme.
Jan 9, 2019 09:22 AM
greenwhite1
Dec 21, 2010 01:20 AM
MichiganHunter
2004 - 2008 F150
May 27, 2008 09:03 PM
OpenTrackRacer
Sep 26, 2006 05:12 PM
rolinron
May 16, 2004 11:21 AM
